Battery drain; testing the current draw.
JimboV8
Re: Battery drain; testing the current draw.
Postby JimboV8 » Wed May 02, 2018 7:05 pm
It is one of the usual suspects and due to the breakdown of the internal battery in the sounder causing the drain. Hope it’s sorted for you. :mrgreen:
2012 XKR, Black pack, Aero pack, Speed pack 8) :mrgreen:
​Past:-87'XJS 3.6L, 93'XJ40 3.2L gold, 95'XJ6 4.0L sport, 00'XJ8 3.2L sport, 2005 XK8 4.2L, 2009 X150 5L Portfolio coupe, in that order and enjoyed all of 'em. :D
Deepdown130
Postby Deepdown130 » Wed May 02, 2018 10:01 pm
If it stays sorted after disconnecting the sounder, I plan to disassemble it and see if I can fit new batteries to it. Then I can refit it.
That guide you pointed me to is brilliant - I now know what all the relays are.
2012 X351 5.0 N/A
2002 XK8 4.2 Coupe (mostly dissolved and now sold)
Deepdown130
Postby Deepdown130 » Mon May 14, 2018 3:19 pm
Just a short update. 2 weeks on and all is well. Looks like the sounder was the culprit. Having recently read June's edition of Jaguar World I note that an owner of an X150 suffered a similar problem and that turned out to be the sounder as well. It is certainly worth starting there if you have similar issues - easy to disconnect and eliminate from your investigations (and doesn't affect normal alarm operation).
Thanks Jimeva for your guidance.
2012 X351 5.0 N/A
JimboV8
Postby JimboV8 » Wed May 16, 2018 10:58 am
You’re very welcome, glad to hear it is now ok. :mrgreen:
