Key fobs not working
painter
Re: Key fobs not working
Postby painter » Wed Mar 13, 2013 2:26 pm
Hello Doug,
yes I did find the light, (looked like a speck of dirt :oops: ), but have tried the sequence many times, still no joy. I don't get the light flashing, nor a chime. Perhaps I have a fault or this oldie precedes the programming facility?
Just to confirm the sequence -
1) pull light lever towards me
2) key in ignition (activates steering wheel position)
3) key to position 1
4) flash main beam 4/5 times (nothing happens here)
5) press 1st key fob then 2nd key fob
(at least one key works)
doug424
Postby doug424 » Wed Mar 13, 2013 5:45 pm
Hello Painter,
Yep that's how I did it.
May be it's time to visit the dealer and cross his palm with silver?
Doug Barrass,
Ashford, Kent.
Orkney
Postby Orkney » Wed Mar 13, 2013 8:33 pm
Hi Painter,
Although I am a blow-in from the X308 BB, I too had similar problems with my recently acquired car. If you have a quick look at the 308 board you will see what I went through to get a result. Eventually it came down to contact cleaning - but not with solvents in the end. I have Paul Gover to thank for reminding me about using an India Rubber (pencil eraser) to clean contacts and the rubber diaphragm. Incidentally I discovered also quite by chance that the 308 system has a lock-out facility, whereby if you keep trying to program, then it will refuse to accept key presses for a time - I don't know exactly what the time period is, but it was like the old key code lockout system on radios. OK when left overnight. Perhaps someone else has that info.
Ian
tomcarey
Postby tomcarey » Fri May 10, 2013 12:15 pm
Hi all...Ref key fobs..XK8...I tryed everything to programe my key fobs...nothing worked...intermitant,,,then not working at all.....(THE SECRECT)....Follow all the normal reprogramming...lights etc..etc....but first ...new batteries....then clean inside fob....next most important....RUB INSIDE RUBBER BUTTONS WITH A PENCIL....my fobs now working perfectly from 30 feet....Hope this helps...Tom.
