Hazard switch stuck
royking999375
Re: Hazard switch stuck
Postby royking999375 » Mon Feb 27, 2023 4:36 pm
The following is a section of the email sent to me by the electronics engineer: -
Roy,
The switches that I used are Farnell Stock No. 2908816.
I made a note in my log book at the time as follows:-
Used switch Farnell Pt No. 2908816 https://uk.farnell.com/c-k-components/k ... dp/2908816
This is a surface mount switch , the original was through hole but the mounting pitch is the same so the new switch can be re-soldered on the top side of the PCB located on top of the existing through holes.
The switch actuator pin height was reduced by filing until the height from the top of the actuator to the base of the switch was 6.9mm. (This matches the height of the original switch as I couldn’t locate a switch with the exact actuator length.) Note however that the actuator stroke is shorter on the new switch than it was on the old. (As I recall I think this affects the feal of the switch.)
I hope this helps, as I say I will have a hunt of the 9 switches that I have got left over.
The above are the notes and comments regarding the replacement switch.
As the switches come in multiples of 10 the is a surplus of 9 switches, which if found will be available should anyone need one.
I trust this will be of interest and used possibly as a follow up item in the magazine.
Postby mike020150 » Mon Feb 27, 2023 4:46 pm
Excellent information, thanks. Mike.
