Speedometer not working
nrandlexj40
Postby nrandlexj40 » Sat Nov 21, 2020 6:15 pm
Speedometer not working - 1996 XK8 Coupe - I think I read somewhere that the speedo is fed from the ABS speed signal from the front wheel - is that true?
My speedo has stopped working and I already have ABS and traction control warning lights - I'm about to check the ABS sensors but would this also affect the speedo?
Neil
1996 XK8 Coupe
2000 S-Type 3.0 V6 SE
2010 XF 3.0 V6
Previous: 1993 XJ40 Sovereign | 2004 X-Type 2.5 V6
Re: Speedometer not working
Postby mike020150 » Sun Nov 22, 2020 11:09 am
Apart from feeding the ABS braking system, the wheel speed sensors are indeed also used to generate road speed signals for the instrument pack. Mike.
nrandlexj40
Postby nrandlexj40 » Wed Nov 25, 2020 9:53 am
Thanks Mike
I'll be cleaning / replacing the sensors and hopefully that will sort the issue.
Neil
1996 XK8 Coupe
2010 XF 3.0 V6
