Front Fog Light
clivesaunders
Front Fog Light
Postby clivesaunders » Thu Oct 19, 2017 11:46 am
XKR Sep 02: Glass has become discoloured, can glass or sections of the light be replaced or is it the complete unit ? If so I assume used spares is the way to go..
Brightness has never been good...any suggestions for type / Watt for replacement lamps
Appreciate your comments
Clive
Re: Front Fog Light
Postby mike020150 » Thu Oct 19, 2017 4:50 pm
The fog lamps are supplied as complete units with a longlife H1 bulb. Jaguar still lists two types for sale at about £70 + VAT each. The lamps were meant to be for use in fog so the beam cut-off pattern is more important than their spread as would be the case if they were intended to be used as additional driving lamps. Mike.
clivesaunders
Re: Front Fog Light
Postby clivesaunders » Fri Oct 20, 2017 1:27 pm
Thanks Mike
Clive
