Hi does anybody know if you can remove what looks like a rubber grommet on the inside of the rear wheel arch of a 2002 XKR which would give you access to the inner part of the cill to spray rust proofer.
jAMES
inner bodywork
Re: inner bodywork
Hello James,
Any chance of a photo to help identify the grommet? I think I know which one you mean.
Doug Barrass,
Ashford, Kent
Doug Barrass,
Ashford, Kent
Re: inner bodywork
Hi.
I did it. It is mentioned in some rust prevention documentation. For the record, mine is a -97.
oyster
X-Type 2.2d Estate 06
XK 8 Cab 97
XK 8 Cab 97
traction392f
Re: inner bodywork
Hi yes the plug or grommet is on the front facing part of the wheel arch, i will attach photo for others asap.
Thanks for replies.
James.
Thanks for replies.
James.
