XK8/R Tail Light Upgrade
analyse
Postby analyse » Tue Jul 13, 2010 1:27 am
My rebuilt 1999 XKR now has an MOT and pending final tweaks will soon be replacing my S Type R as our everyday car. I've bought a pair of the later tail lights with the chrome lens trims but am wondering how much of a task fitting them will be. I've seen several cars with this conversion; anyone any experience of doing this ??
Thanks in anticipation.
Nik
Postby Nik » Tue Jul 13, 2010 10:27 pm
Hi ,
I have the conversion done to mine :wink: and it's well recommended :D
You will need in addition to the rear lamps
1. LH & RH lamp mounting panels ,
these are on back order from Jaguar at the moment and are double the price compared to last year :!:
However Tony at Paragon Design has made these in composite and sells them at a very reasonable price :wink:
2. A complete set of rear inner plastics and firtree clips
3. To rearrange the pin positions of the lamp plugs apart from one pin , although the socket and plugs are identical the wiring positions are not :?
Hope this helps
Nik
analyse
Postby analyse » Wed Jul 14, 2010 7:57 am
Nik thats a great help.
Any idea where I might find a wiring diagram to swop the pins in the sockets ?
Many Thanks ; you're a gent !
Howard.
GrandTourer
Postby GrandTourer » Wed Jul 14, 2010 3:40 pm
Just to add one 'little job' that needs doing:
The existing body apertures which were designed to accommadate the earlier light clusters need to be enlarged to suit the new lights, ie, hacksaw (or similar such as air metal cutter). Also, if you do go for the original metal mounting panels (which, as Nik said, are on back-order by Jaguar), they also need to have some parts of it removed to make them fit (Paragon's composite panels don't need that mod).
I have had all the parts for some years now awaiting an opportune moment to convert the rear lights of my car and that has now arrived - this weekend will see cosmetic surgery to the rear end of my P&J :roll:
Am I nervo-vo-vo-vo-us ?? - you bet I am :? :shock: :shock: :wink:
Karl, XK8 MY2000 Pacific Blue
analyse
Postby analyse » Wed Jul 21, 2010 8:45 pm
NIK:
You were spot on -immediate response from Pragon -very impressed - nice one.
KARL; thanks for this, I'll update the forum when I tackle the upgrade
Top team !
Nik
Postby Nik » Wed Jul 21, 2010 10:13 pm
No probs mate :wink: hope all goes well ,
Nik
GrandTourer
Postby GrandTourer » Wed Jul 21, 2010 10:43 pm
My upgrade was done last Sunday. The car looks fantastic.
Good luck with yours.
Nik, you'll see it on Saturday at the Silverstone Classic - but then, you know what is looks like having yours done some time now.
Great feeling :D Have a good trip down.
Nik
Postby Nik » Wed Jul 21, 2010 11:41 pm
Cheers Karl :wink: see you and your lamps there ,
Nik
