immobilisor doesnt work properly
scatmanvialli
hi, ive got a 1999 xkr with factory fitted immobilisor. the "bleep" has stopped working. i press the key to lock, lights flash, but no bleep. press again to set the deadlock, it locks again, but no bleep. The lock works fine, because i let the wife sit in it while i locked it, and she wasnt able to get out. Come to think of it, maybe i ought to keep her there. Only joking love ( if you're reading this ! )
many thanks,
chris
chris
Hi Chris,
I think you will find that the "sounder" has failed , it can be a problem that effects these models sometimes , replacements are reasonably priced , it's worth noting that the sounder can be switched off according to the owners preference by a main agent or independant with suitable equipment ,
Best Wishes ,
Nik
Edit ......... I forgot to mention that there are two types of sounder fitted to our XK's Active and Passive , make sure you fit the correct one !!!!
Best Wishes ,
Nik
scatmanvialli
