Under the car today and noticed that there was a small leak of fluid. Texture was oily, colour was yellow/orange. The location was the rear corner driver side hex nut, which I think is holding the gearbox cover in situ.
The car is an XKR, I wondered whether this was a gearbox leak or some other fluid.
Any thoughts welcome
yellow/orange fluid
It's always difficult to be sure about fluid sources because, quite naturally, they have the ability to move! However, the location does suggest the gearbox may be the source. Have you tried cleaning around the area, running the car and then rechecking the evidence to pinpoint exactly from whence the leak emanates? If it is a gearbox leak (as opposed to a seep) it should be fixed quickly or other symptoms and possible gearbox damage will occur. Mike.
