reversing sensors on a '99 xkr
Posted: Fri Oct 19, 2007 12:34 pm
by scatmanvialli
hi, i need to get some reversing sensors fitted onto my 1999 xkr. can anyone recommend an installer in the north kent/east sussex area. could do it myself, but i'm worried about colour matching/hole drilling etc etc, so looking for someone who takes a bit of care !
Posted: Tue Oct 23, 2007 11:00 am
by mike020150
If you use the proper Jaguar kit which you can pick up at Stoneleigh/from eBay for £75/£100, it's a straightforward DIY task. When I fitted it to a coupe the worst task was drilling the holes but even that was aided by templates included in the kit. The only point worth bearing in mind is that the standard kit needs an extra relay to be plugged into the boot relay box before the sensors will work. Mike.
