Bank 1 and bank 2
rob1xlb412
Bank 1 and bank 2
Postby rob1xlb412 » Thu May 01, 2025 8:50 pm
Hi can someone please tell me which is bank 1 when you are sitting in the drivers seat, I have had different answers on you tube...I need to replace oxygen sensor upstream bank one.
On a 2002 xk8
MarkX
Re: Bank 1 and bank 2
Postby MarkX » Fri May 02, 2025 9:13 am
Hi Rob,
Jaguar definition in XK workshop manual, as the engines are very similar I can't think they'd change the definitions as that would cause a huge problem for the engineers, dealer technicians etc
References to Bank-1 and Bank-2
References to Bank-1 and Bank-2 are made with regard to the engine. When viewed from the flywheel the right-hand bank will be Bank-1 and the left-hand bank will be Bank-2.
All LH and RH references to the engine are taken from a position at the flywheel looking towards the crankshaft front pulley.
I hope that helps
Mark
rob1xlb412
Postby rob1xlb412 » Sat May 03, 2025 12:08 am
Hi thank you, I have found the work shop manual for the xk8 and bank one is on the right,when sitting in the drivers seat...thank you for taking the time to help me out...
