Just done what I shouldnt!
Posted: Fri Jun 07, 2019 5:09 pm
Having read all the posts over the years on ' don't use a car cover' I havent.
However due to water coming in from pinched door seals in both doors and soaking the floorwells I have relented and just purchased a cover. Apparently it can be put on wet and the condesation evaporates and the company suppy Bentley , Aston Martin etc.
While I understsnd the wheel arches could be damaged its them or a new floor!
Sitting here , soaking wet, I am not sure how to approach the seals and at the moment they will have to stay as they are until I can get in with the hair drier and dry the carpets and fix the seals. New seals are 'mortgage extending ' and its the frame seal tht is pinched which means all the trim has to come off.
if that is the final solution and cant be avoided at least the carpets will be out but for now its car cover time!!
Pat
Pat
