Hi Everyone
I've got a slight issue with my 2002 XK8 and would appreciate any advice.
I bought her with only the green key and the fob was not working. I tested the fob and it is emitting a signal so figured the problem may be the receiver in the boot. Carried on happily driving the car and got a spare key cut at Timspons for £69 which worked.
At the weekend I went to press the boot open button as usual and the car went into valet mode.
Now I can't open the boot and only have a green key and no working fob.
I looked at the key that Timpsons cut for me and it has the different tip from the valet key and is therefore the same shape as the master key and it does indeed lock and unlock the glovebox which the valet key doesn't. When I use this key to unlock the car it doesn't though disengage valet mode which I thought a master key should. Also the keyhole in the boot doesn't work - the black key won't turn in the lock.
So after all this here's is my question - Jag Milton Keynes can make me a new Jaguar master key for £109 - do you think this will work and clear valet mode when I unlock the car?. If the Timpsons one doesn't I have my doubts - is the chip inside the original Jag master key likely to be any different to a Timsons one?.
Sorry for the long post and any advice greatly appreciated.
Best regards
Dave
Valet mode stuck - no black key or fob
Re: Valet mode stuck - no black key or fob
Going into valet mode without pressing the button isn't a typical issue and suggests something electronic has failed or may be failing. However, the problem with the boot lock is more than likely to be a build-up of dirt/ lack of lubrication and use. Consequently, a thorough dosing of the boot lock with WD40 or similar is probably the place to start. After several blasts of WD40, give it time to work and then gently, at first, begin to work the key (which works in the glovebox) in the boot lock. Patience usually pays off and the lock can be brought back into life. A Jaguar specialist with the appropriate diagnostic equipment should be able to diagnose any electronic problem. Mike.
Thanks Mike
I've been spraying WD40 in for the past few days but the key won't budge yet. I'll keep trying and see how I go.
I may have pressed the valet button by mistake when I went to press the boot release but can't be sure.
I'll try over the weekend with the boot lock but if this fails I will try a new key from Jaguar to see if that releases valet mode.
Best regards
Dave
Best regards
Dave
After a few days of spraying WD40 into the keyhole in the boot and genty trying to turn the key she eventually popped open last weekend and now all is good again and the valet mode is cleared!.
Thanks again guys
Dave
Thanks again guys
Dave
Patience is a virtue... Glad it's fixed.
Mike.
Hi Dave,
Glad you got it fixed
and thanks for letting us know.
All to often people resolve an issue and don't bother to report back
and they disappear until they need help on another problem.
Thanks again.
Enjoy your XK8.
Take Care.
Thanks again.
Enjoy your XK8.
Take Care.
For future searchers this may help......... https://www.jaguarforum.com/showthread. ... post701844
