Is it easy to replace a convertible hood frame seal centre o
XK8Dundee
Postby XK8Dundee » Sat Apr 16, 2016 2:06 pm
Hi. I've noticed that the centre hood frame seals are both split,ripped and chunks missing (well actually not just noticed but been ignoring them ) and have now found the seals are actually available. Is it an easy owner fix or does it need to go to a specialist?
Walter
2003 XK8 4.2 Convertible in Jaguar racing green
Re: Is it easy to replace a convertible hood frame seal cent
Postby mike020150 » Sun Apr 17, 2016 4:58 pm
Not quite sure which piece of seal you mean but I suspect it's the middle piece of the horizontal section. If so, I think it took me all of 10 minutes to change one on my X100 a few years ago. I recall it was quite straightforward. Mike.
XK8Dundee
Postby XK8Dundee » Mon Apr 18, 2016 6:14 pm
Hi Mike, the part no I'm looking at is HJB7780AA (& HJB7781AA), hopefully that is what you are referring to and is an easy fix. Any chance you can remember exactly how it was done. I'm guessing it is with the roof down and the old one just pulls out and new one is well lubricated and levered in. Perhaps if I order them I'll get more of an idea.
Walter
Walter
Postby mike020150 » Tue Apr 19, 2016 5:28 pm
Hi Walter,
Subject to it being a few years ago, I don't think it was any more complicated than your guess. However, I do recall wincing at the cost for such a small piece of rubber. (That's the problem with living in Yorkshire and having lived in Scotland!). Mike.
XK8Dundee
Postby XK8Dundee » Sat May 07, 2016 3:20 pm
Wei I've finally got the expensive piece of rubber but doesn't appear to have much of a "lip" to hold it in. Hope it's the right one, guess I'll just have to be brave and pull the old one off and then I'll know for sure!!!
Walter
XK8Dundee
Postby XK8Dundee » Sun May 08, 2016 5:03 pm
Result :-). Pulled old one off and the new one is the same. After a bit of fiddling, squeezing and comparing with other side I got new one in. Put roof up and down and it didn't catch, foul or even fall out.
Walter
Walter
Postby mike020150 » Sun May 08, 2016 5:22 pm
I knew it must have been easy when I did the same job a few years ago. The only residual pain in my memory stemmed from buying the short length of rubber! :D Mike.
