I am looking to buy a late year XK8 and I notice some cars have a small screen in the centre of the dash board and some have the three round dials. I have not understand the reason yet. Was it an optrion or is it year related? Any comments wouold be gratefully received. Thanks.
Dash board screens
Tim Henson
Jaguar 1971 series 3 E type V12.
Rolls Royce 1933 20/25.
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
Re: Dash board screens
Hi Tim - the cars with a screen are equipped with the optional satnav. I have it in my 2001 XKR. To be honest, it's only use is for comedy value as, although cutting edge in its day, it's seriously outdated now.
The 3 dials are probably more useful. (Clock, oil pressure, battery voltage) and combined with either a stand-alone satnav or your using your phone for navigation will give you the best of all worlds.
Hope that helps
Hope that helps
Hi Tim, the small screen is a satnav option, which is so far out of date as to be useless, however there is a magazine article that illustrates how to change out the redundant satnav for a modern, up to date Garmin version. The 3 small dials are typical vehicle instrument information i.e. oil pressure, clock and voltage. The instrument pack is typically the 'preferred option' although that is down to personal preferences.
Good luck with the search and stick around the forum if you want more advice / assistance.
Jim Mann
Jim Mann
Jim Mann
Banchory
Banchory
My XK8 came with the sat nav option and it drove me to distraction rather than anywhere I wanted to go! Out it came, a new Garmin unit took its place and I wouldn't be without that constant source of information whether I'm using it for navigation or not.
There is another option if you'd rather have the gauges, but the best car available has sat nav. That is to get a used set of gauges plus their centre panel and fit them instead. Depending on the 'match' of panels, you might consider a complete, new-used set or finish the centre panel in a contrasting material The vital 'extra' required is the appropriate conversion harness and instructions, available from a small outfit in the USA run by a true enthusiast. You'll see it among his other offerings here - all very high quality in my experience
www.thejagwrangler.com
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
2024 XE 300 Sport
Hi All
Thanks for the very helpfull replies.
Kind regards and happy new year
Tim
Tim
Tim Henson
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
