HMSL Loose
xk82002jaguar
HMSL Loose
Postby xk82002jaguar » Wed May 19, 2010 4:33 pm
The rear brake light on rear parcel shelf/window has worked loose and I can not see how it fixes in place. Can anyone advise.
regards
Mick
D_Doran
Postby D_Doran » Thu May 20, 2010 12:05 pm
Funnily enough, my rear light also is loose. I think it was initially held in place by some form of adhesive to the window itself. I'd be interested to hear what the repair method should be.
Anyone else got the answer?
xk82002jaguar
Postby xk82002jaguar » Sat May 22, 2010 11:09 am
I am a bit dubious of glueing. I have read in the past some members have had problems with the LED's failing. How would you rectify this if it is glued in place?
aaj
Postby aaj » Sun May 23, 2010 12:10 pm
My XK8 (MY2002) has velcro 'hooks' stuck to the bottom of the unit. This then 'fixes' to the Parcel Shelf & can be easily removed for maintenance etc.
As I bought my XK 2nd hand I don't know if this is original or a fix for the problem you have.
XK8 Registrar
xk82002jaguar
Postby xk82002jaguar » Sun May 23, 2010 2:01 pm
Thanks Allen sounds a good fix.
regards
Mick
