I am a new club member and recently purchased a nice 2000 XK8 convertible.
I have notice a puddle on the floor just under the left side just in front of the left rear tyre. It does not smell like gas or oil but could be hydraulic fluid possibly for the top mechanism.
Looking under I see a line with 3 brass fitting. The wet spot is in this general area and also further up on the floor panels.
Any thought would be appreciated.
Tom Ryan
Fluid Leak Left Side
a life threatening situation. Mike.
bloody hell mike you dont mince your words, straight to the point lol
dont worry mate, i have a similar problem i put a drip tray under the it only to find out after a taste test that it was just water (dont taste it , its vile like someones rotting foot thats been baked
turns out its a drain for the air con , well at least thats what the jag dealer said , it might be something more though
, i'll look for you in the obituaries
Having found myself partially or completely without brakes on a number of occasions over the years and survived to tell the tales, I've never found these incidents to be positive experiences. Others may not be so lucky. Hence, IMHO, there's no room for ambiguity when it comes to the basic safety of brakes and similar areas. If you're not sure, you can do a lot worse than asking someone who knows the answer, even if it means paying a Jaguar Dealer. Better to be safe than sorry.
Mike.
Mike.
just trying to inject some humour mike , no harm no foul
i found a bolt under my xkr a few days back so does that mean i need a full engine overhaul?
The hood hydraulics do not leak on these cars unless there's a fault. If you decide to run the car in this condition, ensure you are familar with the manual hood closing procedure (it's in the handbook) and the location/operation of the valve key. I'll bet a pound to a penny that it will fail to operate hydraulically when it's raining! Mike.
