New member with a frustrating problem!
martin.lunt916
Postby martin.lunt916 » Tue Mar 15, 2022 3:34 pm
I have recently joined JEC and hope that someone can help me with a problem. For a few years now my 2 local independent garages have been scratching their heads with a fault with my 2011 XKR. As soon as the car is unlocked the engine cooling fan starts up. Not a problem normally as I will start the car and drive off. However, if for example the car is parked with the engine off and the doors open ( eg valeting) the battery will flatten very quickly. On a few occasions the car has failed to start after washing and vacuuming it. It is showing fault code P0481-13 on the fan control circuit, I have had the fan and control unit replaced (apparently they can't be separated) and a new battery fitted (twice) and the problem remains. The garages now suggest that I take the car to the local franchise dealer but I have no confidence in them! Any suggestions would be appreciated.
Re: New member with a frustrating problem!
Postby mike020150 » Wed Mar 16, 2022 10:59 am
Rather than taking the car to a main dealer, I would recommend a diagnostics session with an independent Jaguar specialist which has a good reputation for electrical diagnostics. The fault sounds to be not untypical of a wiring issue but finding it is likely to be difficult, as you've already discovered. If you are anywhere near Nottingham, David Marks (David Marks Garages) is superb at solving just this type of issue. Mike.
martin.lunt916
Postby martin.lunt916 » Fri Mar 18, 2022 10:08 am
Many thanks Mike, I will take your advice.
Jaguar_Enthusiast
Postby Jaguar_Enthusiast » Tue Apr 18, 2023 9:16 am
I’d be very interested please in whether this problem was fixed and if so what was the solution?
