front interior roof light
Posted: Mon Mar 01, 2021 11:51 am
by coupe
I also need a replacement interior roof light as the plastic holder around the lead on my has disintegrated an so far epoxy replenishing it has failed.
thanks
David
Re: front interior roof light
Posted: Mon Mar 01, 2021 12:58 pm
by ptjs1
David,
With the items that you're now discovering that need replacing, why not give Andy Harvey of JustXJS a ring. He might be able to sort all of them for you including the heel pad?
Posted: Tue Mar 02, 2021 1:05 pm
by PaulGover
Mine did the same some years back; I found a replacement, but while I fitted it, I swapped the incandescent bulb with an LED equivalent, so the plastic doesn't get cooked any more. You have to avoid the ones which still draw the same current, of course - they're designed to fool blown-bulb sensing circuits, which isn't needed for the interior light; they dissipate the same heat as the old bulb.
