Take it out?
Posted: Thu Sep 17, 2009 8:10 pm
by masterb
I've heard a few suggestions regarding exhausts, one being that you can remove the square mid boxes and put a straight through pipe in place.
Or alternatively you can retain the small mid boxes, and then put a nice long pipe on right out to the back, finished off with a nice chrome trim for the outlet.
Anyone tried this/these? I would imagine you really are going to get a growler, with the rear box removed option.
So i would probably favour removing the mid boxes, I am led to believe these are quite restrictive.
So you can gain possibly 20-30 bhp?, and of course gain a pleasing GT growl(if thats your bag of course).
On a similar topic, what do you guys think is a reasonable/good price for a second hand complete, but not including down pipes, stainless steel system in good nick and relatively new??
Got an offer of one,i was thinking 50quid upto 80? unless it's something really special.
Oh and p.s. is the system the same on a v12 as a 3.6 from the mid boxes back? obviusly not same to the front of that with the two lots of downpipes and 2 manifolds.
Take it out?
Posted: Sun Sep 20, 2009 10:16 am
by Jaguar5993
Hi Paul,
As for the rear sections being the same as the V12's,I am not too sure,although, they look the same.I have found using the sng barratt "All XJS Parts Manual"a help for cross referencing and its downloadable for "free"!
I think either option with your manual 3.6 would be fine.I have wasted alot of time taking the middle boxes off and on and off again and now finally to stay back on(see previous posts).
In my opinion,the sound with the mid-boxes removed with an automatic car like mine,was just too noisy/droney(Lancaster bomberish).Probably great with a manual car like yours.
The later 6.0 V12's have larger bores(54mm) anyway,so there is not too much bhp to gain by removing them.
If I had a manual 3.6, I would fit the complete AJ6 Eng. TT exhaust system with the Silencer Substititute Pipes together with their new rear boxes,oh yeh!,if I had the money!!
Good luck.
I know sometimes with a XJS it can be a hard and lonely DIY life, with the lack of replies frustrating,but hang-on in there
Nick 6.0 V12 Coupe 1995
Take it out?
Posted: Sun Sep 20, 2009 10:00 pm
by masterb
Cheers Nick,
I will have to have a look at your earlier posts, re exhausts.
I have to admit that i would go down same route as you with an AJ6 system, but only if i won the lottery.
Seeing as i am somewhat "frugal" or a tight arse, which ever way you want to look at it, there is little chance of one of those systems ending up on my car
I am trying to do my car up on a fairly strict budget, as i have more time than money. so hopefully will get there in the end.
As per your other observation, I have to say that this forum really has gone down hill with few posts, and worse still, little,few or no replies.
Shame really, maybe things will pick up in the dark winter months, when people cant be outside cutting there lawns or trimming there bush.
Cheers For your Excellent reply!!!
Take it out?
Posted: Sun Nov 01, 2009 11:07 pm
by chris211083
hi, i had a full large bore aj6 exhaust for my xjr-s 5.3 auto and loved it. it cost £1200 and half a day to fit. they remap your ecu as well!!! and WoW what a difference. only problem was the ground clearence at the front was reduced. The car could break away the back end in second gear with a quick blip of the throttle. noise was quiet until you open her up and then it roars!!!. For my new car im getting a 12 branch manifold as im told that this will really open up the v12's lungs but ill have to wait as she's being part restored over the next 12 months. that aj6 system was nice.
Take it out?
Posted: Mon Nov 02, 2009 5:57 pm
by masterb
I am just realising how cheap i really am, I have to say the idea of spending 1200 quid on an exhaust would bring me to tears.
I would want a car for that.
Ok i paid more than 1200 for my xjs but i did get a whole car for that, and annoyingly if i had waited 6 to 12months longer to buy a jag i could have probably got the same car for 500 to a 1000 quid cheaper.
Boo hoo, my timing sucks, at least timing on car is good.
Re the exhaust, i am wondering if my local exhaust centre could fabricate me up a pair of substitute pipes on the cheap.
Take it out?
Posted: Mon Nov 02, 2009 7:27 pm
by Mr.Ian
I doubt a 'local' exhaust centre will do it, they'd change your bog standard jag system for another but I recon that'd be it.
Pipe sections straights / bends connectors can be bought seperately for custom one off systems (would obviously be far cheaper than a tuned system).
If you do find anyone to make one you need full formed bends and as few/small a bend as possible (ie 2 x 45s are better than a small 90 bend) or else it's pointless.
You can go the whole hog and fabricate the whole lot from manifold to tail pipe but it will be expensive.
Take your mid boxes off, chop the pipes off and you'll only need 2 x 45s and a straight pipe as you use the original box pipes.
Take it out?
Posted: Mon Nov 02, 2009 10:54 pm
by masterb
Now thats the sort of solution i like Mr Ian!
I had considered the same thing, about chopping the boxes out of my mid section.
I will have to try and find somewhere that will sell me the 45degree bend exhaust sections and a bit of straight pipe.
Will keep me amused with my welder for a while.
Is this diy/home engineering i wonder, or a bit more bodgery!
Take it out?
Posted: Mon Nov 02, 2009 11:46 pm
by iain1980
Southern exhaust supplies in bristol will sell you all the bits you need to take out the centre boxes or fabricate an entirely new exhaust, if you wish, they do pipe, clamps, boxes, you name it.
They normally sell to the trade so are cheap (by jaguar standards!
I don't know if they do mail order as I have always picked up what I needed.
I also know someone in the bristol club who is running a V12 with a copper exhaust from the manifold to the back or the car with no silencer or cats at all, it is best desribed as er, chuffin loud!
FYI If it works it cannot be a bodge, only a bespoke unpretty modification(B.U.
do I need to finish this?)!
Take it out?
Posted: Tue Nov 03, 2009 1:30 am
by chris211083
hi, if you want to have some one fab you an exhaust. power flow will do it for £80ish so im told in stainless. they have shops up and down the country and make custom exhausts. if you go to the power flow site you can see if they are near you?check it out?
http://www.powerflowexhausts.co.uk/dealer-locator/
Take it out?
Posted: Tue Nov 03, 2009 1:31 am
by chris211083
sorry meant the pipes not full exhaust!!!
Take it out?
Posted: Wed Nov 04, 2009 4:39 pm
by masterb
My mate works in motor factors and says he knows someone who will make it up or supply parts locally.
If not though, i work at a site in newport so could always pick up from bristol if worst came to the worst.
Take it out?
Posted: Thu Nov 05, 2009 5:08 pm
by poprivet
This chap has a 3.6 in a locost kit car. Without any exhaust it sounds meaty.
http://www.youtube.com/user/speedyxjs
Take it out?
Posted: Thu Nov 05, 2009 10:41 pm
by steveww
As part of the front suspension rebuild I have noticed that both of the exhaust manifolds have big cracks in them. I was hoping that the exhaust would last until next year but as I am going to have to take it off anyway I am looking at fitting a new system. I am considering the AJ6 Performance system as you can never have too much power. I am, however, concerned that it will be too loud as the refinement is one of the things I enjoy about my XJS.
Does anyone on the list have the AJ6 system fitted?
Take it out?
Posted: Thu Nov 05, 2009 10:51 pm
by masterb
Now thats interesting about the kit car, I just happen to have a spartan kit car which is a project.
Maybe i should pull out the 2ltr pinto engine and box, and cortina rear dif.
And cannibalize the XJS?
In fact the old porka 924 is not very well at the mo and is also rear wheel drive.
Endless possibilities, decisions decisions.
