removing radiator
Posted: Wed Feb 07, 2007 10:51 am
Warning when removing the nuts holding the white plastic P clips holding the metal bleed pipes to the top panel across the top of the radiator These P clips are extremely brittle through age, heat ect and if possible remove with open ended spanner as forcing a socket on the nuts will break the clips .Which I did and now find that they are not available and not listed in jaguar parts book for XJS.
If anyone can help with sourcing these clips would be grateful
Re an earlier posting i did about removing radiator without disturbing the air con yes you can fairly easily if the bonnet is removed.
Thanks David
Thanks David
