Silicon Rubber Hoses
Blackdog
Postby Blackdog » Mon May 12, 2014 3:17 pm
Does anyone have experience of fitting silicon rubber hoses to a V12? Had the embarrassment of blowing a hose after overtaking a queue of traffic the other weekend and I really don't want that happen again.
Marc
1989 XJS V12 Convertible
Glasgow
dhdove
Re: Silicon Rubber Hoses
Postby dhdove » Mon May 12, 2014 4:51 pm
Marc
Received wisdom years ago was that silicone hoses could be unreliable and were more trouble than they were worth, so fit approved OEM items, which, to be fair last for years and years from fitting as new items. Remember there will be some cars that are STILL running on some original hoses :shock:
I have never had a replacement OEM hose fail (tho I'm sure someone will will jump in to say they have!).
But then, maybe technology has moved on in the meantime?
TonyS
XJS Bulletin Board Moderator
Postby ptjs1 » Mon May 12, 2014 6:07 pm
Marc,
I think the concern was that if a silicon hose does fail, it can very possibly split right along its length which dumps all of the coolant immediately. That's not something that you want to happen on a V12!
Just a personal view, but a change to a good quality OEM set would be a better proposition. However, I'm sure there are others who will swear by silicon hoses.
XjRestorations
Postby XjRestorations » Mon May 12, 2014 10:51 pm
Hi Marc,
I would whole heartedly agree with the responses so far.
with many years in the trade - we avoid silicone hoses as they are too unreliable. Good quality cotton reinforced hose sets are readily available and are not very expensive either. Worth replacing with these as it is not a job you want to be doing often - and a V12 is not something you want overheating!
Kind regards,
Keith
Blackdog
Postby Blackdog » Tue May 13, 2014 5:56 pm
Thanks for all your advice, I'll stick with the OEM parts.
Marc
Glasgow
BigCatXJS
Postby BigCatXJS » Sun Nov 15, 2015 1:51 pm
Given the consensus that cotton reinforced hoses are the way to go, would anyone have a link to a recommended kit? I have seen this one http://www.angclassiccarparts.co.uk/hom ... ar-xjs-v12 but would prefer to buy one that has been recommended. Mine is a 1989 5.3 V12.
Thanks, Rich
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
oldtimer
Postby oldtimer » Sun Nov 15, 2015 9:14 pm
I have only owned my V12 for 40years and replaced the hoses once many many years ago.
These of course were Original Equipment Hoses from a Jaguar Dealer
Oldtimer
BigCatXJS
Postby BigCatXJS » Mon Nov 16, 2015 9:01 am
Thanks OldTimer. Being lazy I wanted a kit, but it would not take too long to order up the individual hoses. Seems quite an expensive way of doing it on the Jaguar Classic parts site, but I note that a really good quality silicone kit from Rob Beere is over £300 so .....
Ta, Rich
Past:
1985 E28 BMW M535
Postby Brakebuster » Mon Nov 16, 2015 9:15 am
this is my experience, and not necessarily my recommendation
but eleven years ago i bought and installed the then popular ' kevlar ' reinforced kit that was around, and though not so popular these days i can say i have had no issues with the cooling pipes in the past eleven years, they are still supple and not ' blown' , there are some small linear ' cracks ' along the length on some of the small pipes on the crossover tube connections, but show no sign of failing ,
i will be carrying out a coolant refurb on the engine bank link pipes this winter, and will carry out a closer inspection of the pipework, but it would be a good time to replace as the system is drained and partially stripped, makes sense while in there...... and the kit is only a few hundred pounds, which compared to the annual increase in value is a small price to pay of increased confidence and added longevity in the system
just my thoughts
Postby davidr » Mon Nov 16, 2015 11:04 am
One area worth checking is the tube going into the expansion tank in the wing. There is a metal reduction adaptor in the middle of it that corrodes and ventually blocks allowing pressure to build up. This can lead to very high pressures in the cooling system and possibly blown hoses.
I do have experience of this! My V12 blew a top hose a few years ago!
This may have been the reason for the OP's problem?
