Temperature gauge
Hydie
Temperature gauge
Postby Hydie » Sat Sep 10, 2005 9:39 pm
I don't know if anyone can help but my temperature gauge hardly ever moves off the bottom of the cold mark. Is this normal? I have an XJS 4 Litre
Telsmoneypit
Temperature gauge
Postby Telsmoneypit » Sun Sep 11, 2005 1:20 am
Change the stat. My 3.6 had the same problem when I first got it. New stat and needle back to halfway between c & n (which is normal for an XJS)
Tel
XK8 Antigua blue (with issues)
2005 X-Type Sportbrake (Triggers broom)
2004 X-Type sportbrake, 1967 S type ..and my lost love..1990 XJ-S 3.6 coupe
WULLIE4567
Temperature gauge
Postby WULLIE4567 » Thu Sep 29, 2005 9:34 pm
I have a 4.0 ltr xjs 92 face lift. just seen your ??? you didnt say if you were getting a good heat from your heater or not ? if you dont have much heat from the heater yes it could be your thermostat. If you have a good heat, it could be the temp transmitter it's self, you can do a quick check to see if your gauge and transmitter is working by earthing the wire to the housing getting someone to watch the temp gauge at the same time - it should climb up to the red mark. dont hold it on to long just to see if gauge rises. if it does rise your gauge is ok, replace the transmitter.
If the gauge does not rise the gauge or the resistor for the gauge may be faulty.
hope that helps :lol:
wullie.
Mark_B
Temperature gauge
Postby Mark_B » Fri Sep 30, 2005 1:08 pm
Another view on it....
Temperature guages on Jags are notoriously inaccurate. I had one. The only sure way of knowing the temperature is measure it yourself.
The easiest way is to ask around and try get a borrow of an IR thermometer and just point it at the head. It should read 88 degC or thereabouts, depending on thermostat fitted. The block should read a little lower, because it's the head that's the thermally stabilised part of an engine. You can buy an IR thermometer from Farnell for about £30. www.farnell.com
If all is well with the real temperature and the gauge is still lies to you, there are various schemes people have devised that a newsgroup search will uncover. I personally use a current-doubler module connected to the temp sender that's work fine for many years, I'd done this because even with the right stat and sender and no other apparent fault,, I still had a low reading even though the temperature was right, this transistor gadget thing makes the reading correct.
XJ-S 3.6 230k miles +
Hydie
Temperature gauge
Postby Hydie » Sun Oct 09, 2005 6:15 pm
I would like to thank everyone for their kind and prompt relpies, the mystery of the temperature gauge not moving from cold, has now been solved. I changed the thermostat and hey presto the temperature gauge is back to normal and the car is now nice and warm inside.
Hydie
:D
Martin
Temperature gauge
Postby Martin » Mon Oct 10, 2005 3:33 pm
Mine also reads halfway between C and N. (1989 3.6). Is that considered normal?
Damian.Gardner
Postby Damian.Gardner » Wed Apr 12, 2006 11:52 am
So does mine now I have changed the stats, wonder if half way between C and N is correct for a V12 5.3 HE =/
Damian
Mark_B
Postby Mark_B » Wed Apr 12, 2006 9:44 pm
This 'half way between C and N' had bugged me the first week I got the XJ-S almost 10 years ago, and Newsgroups and Jag-lovers.org also often complained that when the Rad is boiling over, the gauge still didn't go higher than 'N'. That's why I connected my Amplifier gadget to the Sensor tags ! My previous car was a beemer, the gauge read dead-centre, I was used to that.
Postby ptjs1 » Wed Apr 12, 2006 11:05 pm
Mark,
Excuse the electric ignorance but from where would I get a current-doubler module. Forgive me for taking the thread off at a bit of a tangent, but I have the same temp gauge reading problem on a Range Rover. Do you just fit the module in line between the sensor lead and sensor terminal or something else?
Tks
Mark_B
Postby Mark_B » Wed Apr 19, 2006 1:29 am
Ooops! I'm told by acquaintances of mine I too much expect everyone else to be skilled in electronics and technology and I often forget not everyone has my electronics skills, it's ok for me I can think of an electronic idea and then design it, that's my job! I guess I ought to disclose it now I've mentioned it.
Current doubler is a relatively common electronic component part connected up in a certain way: 2 wires from the module, (a,b) connect between the sensor and the wire just removed from it, and a 3rd (c)to any nearby ground.
It works by any current flowing into the water temperature sensor will cause a duplicate of this current to flow from the module point direct to ground, bypassing the sensor. These 2 currents add together, a).
Existing circuit:
Gauge-------->-------------------------------Sensor----->-----Ground
Doubler added:
Gauge-------->->-----------a) MODULE (b------>---------Sensor-------->-----Ground
MODULE
(c -------->--------------------Ground
Module is made from a BCV62 current mirror device, with 3 wires tacked on: a,b,c and covered in a big blob of epoxy resin to make it robust.
pin a = device pins 3&4, to a 1/4" lucas male
pin b = device pin 1, 1/4" to a lucas female
pin c = device pin 2, to a ring tag
can buy a from www.farnell.com
The BCV62 is a really tiny part 2mm across, http://www.semiconductors.philips.com/a ... CV62_3.pdf would need an experienced person with soldering iron and a steady hand.
poprivet
Postby poprivet » Wed Apr 19, 2006 5:31 pm
:shock: Can't we just bend the needle a bit? :wink:
Pop
HerefordMark
Postby HerefordMark » Wed Apr 19, 2006 6:21 pm
I would try the obvious before getting into all this electrickery stuff. I have just rebuilt the cooling system on mine, and the gauge was still playing up, despite new thermostats and sender unit. I dismantled the instrument panel, removed the gauge, and cleaned up the contacts (odd screw based mechanism that only Jaguar would bother with). Then I gently moved the needle through it's range of travel a couple of times, before using a bit of WD40. Result - gauge sits bang in the middle of the scale, and does not move, even when left idling. There isn't much of a signal coming into this gauge so it pays to make sure that it can use all it is getting. Worth a try before getting out the soldering iron?
cya266x
Postby cya266x » Thu Apr 20, 2006 10:56 pm
Pop rivet; your response is absolutely great!
If anybody still cares, I also have a water temp gauge that moves from cold to half way between cold and normal. I'm pretty sure the jag-lovers site covers this (if not it's in the Kirby Palm "experience in a book") where the popular remedy is to clean-up contacts in the instrument panel. I'm going to have a go at this when I get sufficiently motivated or worried that the needle is physically prevented from moving any higher.
But it would be reasonable to conclude from these posts that halfway between cold and normal is "normal" on a V12.
David - 1982 XJS HE
Mark_B
Postby Mark_B » Sat Apr 22, 2006 10:49 am
I really like Pop's view! The easiest solutions should always try be sought first.
Can't we just bend the needle a bit? :-)
Pop
Personally, I found the 'leccy technique of mine the easiest, but then it would be, I'm a rocket scientist :-)
Graham
Temp. Gauge
Postby Graham » Wed May 10, 2006 10:17 pm
A slightly different problem with my temp gauge on 1996 4.0l Celebration Coupe,it rises to N and stays there for about 30 miles then decides to slowly creep uptowards the H.When stopped in traffic the gauge then starts to come back towards the N mark.It hasn't as yet hit the H mark but comes closer each day.
