Front Subframe Mounts
Postby davidr » Wed Dec 27, 2006 7:53 pm
Dear All,
I am replacing the front subframe mounts on my 1989 V12. The front (six-shot) mounts came out after some "persuasion" and have been replaced OK.
The rear mounts are giving me trouble!! The 2 bolts that are visible from underneath are relatively easy to get a socket onto and have come off with a bit of muscle power. The front bolts have to be accessed from above (having taken the air filters off). My problem is that, although I can just about get a spanner on them I can't shift them! It's just too awkward to get any strength on it.
Has anyone got any ideas how I might get them off?
Your help and experience would be much appreciated.
David R
wolf
Postby wolf » Fri Dec 29, 2006 11:00 pm
Try a crow foot wrench, I found them useful for removing the outer exhaust down pipe bolts which is another nigh on impossible bolt to get onto unless the car is on a lifter.
Please understand i'm only making a best guess as i've never had the pleasure of this particular job. even the thought of it makes me cringe.
Hope this is of some use and best of luck
Postby davidr » Sat Dec 30, 2006 8:31 pm
Wolf,
thanks for the tip - I've just ordered a set of crow foot spanners on e-bay - I'll let you know how I get on.
I've tired taking down-pipe nuts off form above and it caused alot of bad language and removed the skin from most of my knuckles!
I've recently moved and now have a workshop with an inspection pit - from underneath this job is MUCH easier - you can get a socket and a long bar on the nuts and apply the necessary muscle.
The effort involved in digging a hole in your garage floor must be worth it - it makes so many jobs so much easier.
David R
dhdove
Duck Pond
Postby dhdove » Sun Dec 31, 2006 8:12 pm
David R
Many years ago my brother in law and me put an inspection pit into the garage of the house he had just moved into.
It was lovely, until it started to rain............. 8)
DH Dove
XJS Bulletin Board Moderator
Postby davidr » Thu Jan 18, 2007 8:08 pm
I've tried the crows foot spanners but I can't get free enough access to the bolt head to get them on in the right position to get the socket extension in. Still, they'll be useful for other things I'm sure.
Anyone got any other ideas?
Mark_B
Re: Duck Pond
Postby Mark_B » Sat Jan 20, 2007 1:22 pm
David R
DH Dove
:-) I know someone who fitted a Bilge Pump to his Pit because he found his property was built only 3 feet above the water table!
I've done the v-shape front mounts, in my pit, and I was lucky they came undone easily, if I remember rightly I used a long shafted socket set with UJ or something like that.
XJ-S 3.6 230k miles +
Postby davidr » Sat Jan 20, 2007 8:49 pm
Dave Marks has advised me to undo the nut that holds the subframe to the mount, undo the back bolt that holds the mount to the chassis and then drop the subframe by a few inches (careful not to go too far or hoses will be stretched and the fan will get damaged). This should give a bit of room to work. He then says the easiest thing to do is to get a lever under the mount and break it off. Apparently it's quite britte. Then I should be able to get at the other bolt.
I've not had a chance to try this yet (she who thinks she is obeyed has me on a building project :( ) )
Not sure if I like the idea of deliberately breaking something but we'll see!!
dhdove
Vandalism
Postby dhdove » Mon Jan 22, 2007 8:00 pm
DavidR
If Oracle DM says thats the way to go..................
Have Faith :wink:
DH Dove
Postby davidr » Sun Feb 11, 2007 6:59 pm
I did as Dave Marks advised and it worked - a little brutal but certainly effective. The resolute application of a long bar and a big hammer from above broke the old mounts in just a couple of hits. It was easy then to get the previously hidden bolt out. Not so easy to get that one back in when putting the new mount back, especially on the nearside where there is NO room to work. A stubbier 9/16ths spanner would have helped as there's little room to swing a conventional one as the steering fluid cooler gets in the way. The offside is easier as there's more room to work.
Test drove the car today and it's cured my vibration and ride quality issues (see separate strand).
So, thanks to Dave Marks (all hail the Guru!) and I hope my clumsy blunderings are of some use to other people wondering how to do this.
