Front Wheel Bearings
Speedbird1
I have some oil (dirty grease?) coming from around the 'leaper' in the centre of my front offside wheel. Is this a wheel bearing gone or about to go? If replacement is needed is it a task within the capablities of an average DIY mechanic ; any recommended grease to pack the bearings with (CastrolLM?) and, finally, any known pitfalls in the job.
Wheel Bearings
Speedbird01 (BA Heavy?)
Welcome to the XJS Bulletin Board
I haven't done my own wheel bearings in the past, entrusting them to my garage, but would offer the following pointers..........
Bearing kits themselves are not expensive , about £30.00
If the front wheel bearing is on the way out you WILL hear it, constant droning which is worse on one lock than the other.......... I can never remember which way indicates which wheel
easiest sort is to jack under the front sub-frame and spin and rock each front wheel, this will indicate any problem straightaway....
Re home replacement, I dont think they're any harder than other motors, tho you have to remove the complete front hub assy........ but be aware , correct adjustment of end-float is critical........otherwise new bearing will be u/s in short notice. I believe the way to go is to fit, adjust, drive "round the block" and then re-jack and re-check and ajust end float.........they should not be tight, but check factory manual for end-float figures. ie there should be "a little bit" of rock in them - I would estimate approx 3/32 inch or less at the tyre circumferance.
As a first step, prize off leaper and see whats leaking????
Other BB members will, I am sure supply further details
Good Luck
DH Dove
Good Luck
DH Dove
XJS Bulletin Board Moderator
Speedbird1
dh dove
Thanks for taking the time to reply. I had a go at the work this PM and didn't get beyond step 3 - removing the bolts to release the brake disc. Oh, the things the workshop manual doesn't tell you! Like the fact that the aperture in the disc cover is inward facing and its nigh on impossible to get a socket onto one of the nuts...and when you do there isn't either a)enough room to get the socket rachet in place or b) the socket is too far inside the disc cover aperture for the ratchet to make contact. I can only think that the car has to be up on a ramp at eye level to stand any chance of getting at those bolts.
I did, however, clean up the hub and there was some grease 'slopping' around so I'll keep an eye on things.
Also, I noted that the bushes on the anti-roll bar link were on their last legs so that is the next (potential) job.
Wheel Bearings
ah the Jaguar book of lies.........
How much rock/play/noise was there when you got the car jacked?
DH Dove
DH Dove
Speedbird1
Negligible/nil. I think that the bearings are Ok and that the 'dribble' might have been some water mixing with some greasy muck in the end of the hub. Lying in the bath and thinking about the 'inaccessibility' problem it did occur to me that all I had to do was apply right lock and the disc plate would have been facing almost forward thereby making the aperture easier to get at.
As I mentioned, what did come to light was that the anti-roll bar down link bushes are dreadful. Again, looking at the manual it appears that all the job entails is removing 2 lock nuts, top and bottom, but how easy/difficult is it to get the anti-roll bar itself up and off the top of the link?
the anti roll bar links are very easy to replace,
you can actually get a kit that supplies all the new parts you need
( link bar x 2 , nylock nuts x4 , washers x8 and bushes x 4 ) for around £25 ,
be aware that there are two sizes of washers , one fits against the bar, and the other for the outer end,
the only real techinical thing you have to watch out for is that both road wheels are at the same height at the time of changing the washers, if one wheel is higher than the other you are puting tension on the bar ,
both wheels at the same height will mean no tension on the bar facilitating the removal and replacement of the bushes ,
once the nuts are removed, the bar simply pulls off the link ,
this simply means , jack the car up in the middle ( ensuring the back wheels are chocked ) and take of both front wheels , for a simple safety action , place the front wheels under the front of the sills, if the car falls , it falls on the two wheels and not you
you may also wish to look at the anti-roll bar mounting bushes, these are held to the subframe and are also easy to change ,
hope this helps
Vince
hope this helps
Vince
Speedbird1
Speedbird,
With the wheel on full lock, I found that I could undo the nuts using a short "wobble-bar" extension on the socket and using a ratchetless ratchet. It's a bit of a pain but it is possible. Get all the extensions, wobble extensions, U/Js, 1/2" - 3/8"- 1/4" socket adaptors and ratchets that you've got and play around until you find the best combination.
Speedbird1
Speedbird1
There is a chap on ebay, markets as 'v12' from the US of A, with a replacement drop link kit that includes polyeurethane bushes. Has anybody used this kit?
Haven't used this supplier for these parts but can vouch for his LED instrument panel lamps, (best £30 i've spent in years), Got my drop links from K.W.E. really helpful and friendly
On the subjet of "V12", have you seen the twin electric fan assemblies he advertises, wonder if they perform as well as they look?
Telsmoneypit
I've used these anti-roll bar drop links from V12 - they went on quite easily and are performing well so far.
I can vouch for these as well. V12 even gave me a 'free replacement guarantee' should the bushes ever fail, which was impressive!
These have already outlasted the OE bushes that I fitted 3 years ago (failed after 12 months use)
Tel
Tel
