3.6 front subframe replacement
Posted: Thu Nov 02, 2006 8:30 pm
by Telsmoneypit
Failed MOT yesterday on corroded spring mountings. Oh joy...
The tester reckoned that "if you removed the springs you could plate them up with a mig". Yeah right. As if I'd waste my time faffing around trying to weld to rust!
Anyway, I found a replacement subframe courtesy Eurojags which should be on it's way very soon and need to get some other bits before I can proceed with the work. What I am lacking is the correct spring compressor. I know I can hire one from the club, but £40 seems a little steep to me for a weekends borrow.
Has anyone out there got one that they'd be prepared to lend me? I would be happy to pay all postage costs (and enough for a drinky or two!).
I'm planning to do the work next weekend (12/11/06) so if anyone can help please PM me pronto.
cheers
Tel
Posted: Fri Nov 03, 2006 4:38 pm
by Brakebuster
erm,
do you mean the spring mounts in the bottom have rotted out,
if so, why are you replacing the whole subframe whn all you might need are the cups under the springs, which are bolted in ?
plus, a set of spring compressors would prolly cost you £10 each way to P&P, plus your ' drinky' almost takes you to the £40 ?
good luck with the project
Posted: Fri Nov 03, 2006 6:15 pm
by Telsmoneypit
BB, I am replacing the whole frame because the TOP mounts are rotten. The lower cups are sound. Believe me, if there was an easier and cheaper way of repairing the car I would find it.
A set of spring compressors
maybe you think I'm doing the rear frame, no. I am doing the front of the car. As far as I am aware, the safest way to do this job is to use the correct (singular) Jaguar front spring compressor which retails at @£200! Ok, £40 doesn't sound much to hire the tool but the cost of the parts are already mounting up and I thought I would ask here just in case someone has one .After all, I have lent tools to people on this message board in the past and thought that maybe someone could help me out this time.
Tel
Posted: Tue Oct 23, 2007 4:01 pm
by poprivet
I expect you have got over the problem by now. However, that compressor is now £260 ouch!
I had a good look at one the other day and to be fair it would be difficult to replicate it safely at anywhere near the price. Lots of complicated surfaces, angles and heavy steel.
BB hit the nail on the head, its not so much the hire cost but the postage or collection & return which makes the cost escalate, plus I'm not sure how long the hire period is. It would be annoying and costly if it had to be hired twice.
Pop
Posted: Tue Oct 23, 2007 6:46 pm
by dhdove
"I expect you have got over the problem by now."
DH Dove
Posted: Tue Oct 23, 2007 11:45 pm
by Hosier77
I looked at the Jaglovers xjs eBook thingy, which went on about other methods of changing the front springs.
I tried these, and to be fair i successfully changed my front springs, but it was one hell of a job and the faffing arround was unbelievable, not to mention the safety aspect.
If i do it again, i will definately use or make the correct tool!
I worte a bit on it at ;
http://www.rhel.co.uk/jag/sprongs.htm
