3.6 manual Creaking front end
PhilDobson
Postby PhilDobson » Mon Oct 02, 2006 10:55 am
Driving me mad! i can reporduce it whilst stationary by rocking the steering from side to side. (without the engine running) it sounded like it was coming from the rack turret. However it isnt as i changed the rack. No play in any of the joints that i can see. Cant pin point it.
Any sugestions would be appreciated.
Best regards
Phil Dobson
Mark_B
Postby Mark_B » Tue Oct 03, 2006 2:04 am
Well you're quite fortuanate, if you can get it to squeak away to order rocking the steering you're halfway there to finding the problem already, as opposed to those really annoying knocks and squeaks you can only hear when driving.... If you're underneath / under the dash and the sound can't be located easily, listening around through a bit of small bore tubing is quite good for direction-finding I found, even better when you poke a small funnel in the free end of the tube for better pick up!
XJ-S 3.6 230k miles +
PhilDobson
Postby PhilDobson » Tue Oct 03, 2006 8:18 am
Thanks Mark. I think we will need to be able to add audio files to these messages so we can post the noises on this sie for people to diagnose/fall about laughing!
I will update as i trace it.
