Am I doing something wrong do you think? I redid all my top wishbone bushes about 3 yrs ago but they'd failed already due to water ingress.
You can tell they'd failed by tell-tale rust deposits (from the fulcrum shaft) showing on the rubber parts, and an 'offset' look to the way they 'sit'. When I did them (and yesterday) I put absolutely loads of grease all over the metal moving parts, avoiding getting grease between the rubber/metal interface where only hydraulic fluid allowed.
Maybe you're meant to use waterproof grease? Or special grease of some sort? Or no grease at all? Or are you meant to apply some special sealer over the top of the assembly that only an inner sanctum of select people know about or maybe I was just unlucky. The Haynes book is useless as usual, just tells you to take everything to a myriad of tiny peices, then "... assembly is reverse of dissasembly..."!
Anyone done these Top Wishbone Bushes before had better luck than me?
Top Wishbone Bushes lifetime
XJ-S 3.6 230k miles +
