Original Finish
steveww
Original Finish
Postby steveww » Tue Nov 03, 2009 10:00 pm
I now have the front suspension stripped down. Most of the components had surface rust which has now been removed with some light wire brushing.
I was curious to know what was the original finish on these components? Where they originally painted or plated etc?
Original Finish
Postby Brakebuster » Tue Nov 03, 2009 11:16 pm
most of the items were painted black
you could use chassis paint, or you could get them powder-coated
but black paint will do
i dont like hammerite, unless sprayed on, brushing just doesnt work
steveww
Original Finish
Postby steveww » Wed Nov 04, 2009 5:21 pm
Thanks for the info.
Hammerite is OK if you put it on thick, it sort of self levels and gives a reasonable finish. Spraying it also works well and does give a better finish. Depends what you are after? Protecting the metal parts or concourse finish?
