Ball joints
steveww
Ball joints
Postby steveww » Sun Nov 01, 2009 9:05 pm
In the middle of a front suspension rebuild. I have a problem with the upper ball joint.
I have the bug nyloc nut partly undone and the ping has broken loose of its taper so now the ball rotates with the nyloc thus I can not undo it any further.
Any ideas here?
So far the only thing I can think of is cutting a screw driver slot in the end of the thread, so I can use a screw driver to hold it while I use a ring spanner on the nyloc.
Mr.Ian
Ball joints
Postby Mr.Ian » Sun Nov 01, 2009 9:13 pm
The nyloc is now turning the ball joint instead of coming off?
Is that what you mean?
Try to force it back into the taper to undo it off the nyloc.
1978 XJ-S V12 Auto - Under Restoration
Mr.Ian
Ball joints
Postby Mr.Ian » Sun Nov 01, 2009 9:16 pm
You could try and use a big 'G' clamp to clamp it down and lock into the taper again.
poprivet
Ball joints
Postby poprivet » Sun Nov 01, 2009 9:22 pm
At least the taper is free!
Hacksaw or angle grind the nut off. You will be using new ones anyway, being one time use nylocks.
steveww
Ball joints
Postby steveww » Sun Nov 01, 2009 11:46 pm
Alas the nyloc has not moved enough to get the angle grinder in but that may be an option, I love using the angle grinder :twisted:
A hack saw would take for ever as that has got to be very hard steel in there. Now might be the time to increase the tool collection with an air saw.
First I will try to get the taper to lock in again first.
steveww
Ball joints
Postby steveww » Tue Nov 03, 2009 10:33 am
UPDATE
No way could I get the taper to engage again. I used a bit of heat to melt the nylon in the nyloc nut and this allowed it to undo some more before the ball started to turn again with the nut. Now I had about 1/4" enough to get a saw blade in. The tool collection has grown with the addition of an air saw :D Using this it only took a few moment to cut through.
