Shims
steveww
Shims
Postby steveww » Thu Oct 29, 2009 9:52 pm
This is rather embarrassing but here goes :oops:
While taking apart the front suspension I was removing the brake calliper, 3 M12 bolts also holding on the steering arm. As the assembly came away some thin washers (shims) fell to the floor. I am not totally sure where they came from? They may have been under the steering arm and/or the brake calliper?
Any ideas? How do I test measure that I put them back in the right place?
iain1980
Shims
Postby iain1980 » Thu Oct 29, 2009 10:59 pm
Don't worry, I did the exact same thing the first time I took one off. As I remember, there are;-
One bolt that holds the caliper, another that holds the steering arm
and a shared bolt. The shim(s) go between the caliper and the steering arm on the shared bolt. They are to remove any stresses the steering arm.
If you have lots of shims then they also used to be added to centralise the caliper to the disc, but I haven't found any there yet.
When taking suspension apart it always pays to put a dab of touch up paint anywhere there could be shims, that way if the drop out unseen, you can match the paint dabs up. Hindsight is 20/20 though!
To get them back in, you can tie dental floss to them and then cut it off before tightening.
Hope it helps.
steveww
Shims
Postby steveww » Fri Oct 30, 2009 10:31 am
Very useful, thanks :)
