I have a 1996 celebration model. It is my ninth Jaguar and I am again delighted with it. I bought it a year ago with 68k and full history. I left the car to Charles Hursts in Belfast for a complete going over ealier this year. The bill for the entire service came to £2250 sterling however, the steering still feels a little odd. When I drive over rough roads I can feel it coming through, also a little knock coming from the drive tunnel.
Jaguar tell me there's noting to worry about however, after owing so many Jags I beg to differ. I would be very grateful for any ideas.
Steering feel.
Steering feel.
hi and welcome
its possible that the gearbox mount has worn, there is a bush and spring setup at the bak of the gearbox, if worn will give excessive movement up and down, this usually manafests in seeing the engine move dramatically when pushed ( or revved )
good news is, cheap and easy to fix ( on a ramp )
or it could be the usual exhaust bracket banging on the body underneath
as for the steering,, could be anything....?
hope this helps in some way
Steering feel.
Hi I agree with brake buster, the gearbox mount is probably causing the knocking. they disintegrate at the rubber bush.
The steering rack bushes are another known weak spot. Noticeable when you find the wheel has to be turned an inch or two before the wheels turn. If you turn the steering wheel while watching the rack, you can soon see if the rack moves.
My Pre He. rack went back and forwards a long way. New bushes are a cheap fix. There are sports bushes and poly bushes as replacements.
regards Kels.
regards Kels.
Steering feel.
My XJS also has a loose feel to the steering only noticeable on rough country roads. I have identified it as a tired ball joint in the suspension. To check this take a firm hold of one of the front wheels and give it a good shake in all directions, you not not be able to feel any play at all.
Steering feel.
If you can wobble the wheel when jacked up it could be bearings or joints, what i've found is if you have someone press the brake pedal hard while you try and wobble the wheel this will stop any bearing movement. If you still have movement it's ball joints or track rod ends, if not it'll be hub bearings.
As stated though steering rack bushes are known to be weak and are worth changing anyway.
1978 XJ-S V12 Auto - Under Restoration
Steering feel.
Gentlemen thanks for the replys, here's were I am so far. My rack bushings and gearbox kit have not arrived yet from British Spares, the post strike most likely. However, I have found the invoice from Charles Hursts that covered the last service and here goes, Carry out annual service,replace wiperrubbers,replace n/s/f indicator assembly,carry out coolant change,change gearbox oil,carry out brake fluid change,replace n/s/f and o/s/f ball joints,replace n/s/f and o/s/f upper ball joints,replace n/s/r and o/s/r trailing arms, replace front antiroll bar links, repalce rear bump stop rubbers,replace n/s/r fulcrum bearings,replace o/s/f top arm bushes,grease joints,carry out aircon regas. Total price 1820 including 50% discount on the labour. The labour had been charged at 1375 but because the car is over six years old they drop 50% off.
So that's were I am now and still have a rough feeling to the steering when I drive over rough ground.
God know's if I will ever see the parts that were posted but, if they arrive I will fit them and get back to you. Any more ideas would be appericated.
Steering feel.
Steering feel.
Thanks Jed, the tyres I had replaced six weeks ago same story.
Steering feel.
I've had this similar/same problem, not on an XJS mind you (got one but not driven it yet
It felt like every slight bump in the road was transmitted through to my hands holding the steering wheel. I traced it to the track rod ends, there wasn't a lot of movement when trying to wobble the road wheel but the bit that was there (directly connected to the rack) just fed it through the steering to the steering wheel.
How does it feel when you move the steering wheel very slightly left to right without the engine running - you might be able to detect a slight knocking feeling.
Just an idea.
Just an idea.
Steering feel.
Mr. Ian Many thanks, I have just tried that and the wheel moves a little before the wheels move. Car is going to Northern Ireland today for it's MOT, have to confess that I am looking forward to the three drive from Wicklow to Newry in County Down and three hours back. Anyway, I will see how it gets on with said MOT and will have a look at what you have suggested when I get back tommorow.
Users browsing this forum: No registered users and 16 guests
