Poly bushes vs standard
steveww
Postby steveww » Thu Oct 01, 2009 4:05 pm
This winter I will be refurbishing the front suspension which will involve replacing all the bushes. I notice the usual suspects sell both poly and standard items.
Any opinions on what is best?
The poly bushes should last longer but may give a harsher ride but with more positive feel???
Any experience out there???
Postby Brakebuster » Thu Oct 01, 2009 5:23 pm
i have fully restored both the front and rear suspension on my 1989 V12 coupe
i thought about it this way
the ones jaguar fitted lasted nearly twenty years, the design life of any car is 10 years, so they didn't do that bad,
i fitted original matalastik bushes rather than polly one..
reason being, i should get a minimum of another ten years at the original ride quality Jaguar designed into the car......
fitting polly ones does give a firmer and sharper ride, but is that what you want ? if so , go for it,
but remember the bushes you are running on are worn, and fitting original spec will tighten it up no end compared to what you are currently experiencing, fitting polly bushes may ( will ) make it a much harder ride,
the Polly bushes being harder also transfer stresses and fatigue to different components on the suspension , possibly making other components fail sooner than they should
well worth thinking about both types
kelsham
Postby kelsham » Fri Oct 02, 2009 3:38 pm
Hi, I made the mistake of fitting sports bushes to a TR7, they made the car extremely harsh to ride in.
I would think carefully before fitting them.
The original Metalastik bushes are of good quality. Do you want an XJS ride or a kit car feel?
regards Kels.
masterb
Postby masterb » Fri Oct 02, 2009 8:43 pm
I've got poly bushes already on the top off the shocks, and have yet to fit the poly ones i got for the steering rack,anti roll bar and the i have ones for the upper and lower wishbones.
I might not fit the wishbones ones, but i think it is reasonably well accepted that it is a good improvement swapping the steering rack bushes and roll bar bushes with poly ones? :D
By the way if someone is really bored could they snap me a pic of the steering rack bushes and put a circle round them with there digi cam.
Preety sure i am looking at the right bit , but would be a bit more reasuring if i knew 4 certain before i start.
Cheers PaulB :wink:
jonc3725
Postby jonc3725 » Sat Oct 03, 2009 12:25 am
I replaced all my bushes with poly ones apart from:-
1. Front subframe main bushes (replaced with original)
2. Rear cradle main bushes (replaced with SNG barratt harder version)
3. Radius arm bushes (replaced with original)
All the Nylon bushe are normal ride bushes and not fast road or boy racer types.
PaulB my car is up on ramps so I will get a photo of the steering rack for you.
1986 3.6 MANUAL (WAHOO FINISHED FULL RESTORATION!!!!!!!!!)
1998 MK IV TOYOTA SUPRA TT VVTI
LIVING THE DREAM
masterb
Postby masterb » Sat Oct 03, 2009 9:36 am
Thanks very much jonc,
I am pretty sure i am pretty sure i have spied the ones to swap in the steering rack, but there is enough doubt to make me worry.
Must be great to have a ramp, i end up working on a concrete garage floor with my nose about an inch off what im working on, under axle stands.
Thanks Again.
Perhaps we should all photo jobs we do in a step by step manner, so that we can post on here 4 others who are about to tackle similar jobs.
P.s.s
Anyone want to own up to driving a turquoise cabriolet up the a34 on thurs afternoon about 3 ish, was driving home from a training course in newbury when i spotted this XJ'er.
poprivet
Postby poprivet » Sat Oct 03, 2009 11:21 am
Paul, here is a link to a picture of them,
http://www.britishparts.co.uk/.sc/ms/bd ... OUNT%20KIT
What they never supply is the washers needed to bush them correctly, basically you need some 'penny washers' to eliminate any lateral movement. I think a better description then I can give is somewhere in Kirby's book.
Steve, yours is a celebration model? Quite likely you have the sports rack bushes anyway, I think the other Paul ptjs1 has some experience of the difference, maybe he can add more.
steveww
Re: Poly bushes vs standard
Postby steveww » Sat Oct 03, 2009 5:11 pm
Where did you get the bushes from?
Postby ptjs1 » Sat Oct 03, 2009 8:25 pm
steveww,
All late 4.0 litre models racks use the same setup as the 6.0 JaguarSport configurations which is:
1 standard bush CAC 1635
2 x stiiffer bush CBC 9107
I changed all 3 of mine 5 years ago for 'urethane bushes and have been very happy with the result. I don't think that they cause more sustained wear on the rest of the suspension bushes but it's difficult to know.
Just a personal view but, for a road car I tend to think that very positive steering with a degree of compliance in the suspension is the way to go.
There are differing schools of thought as to whether it's best to change the wishbone & sub-frame bushes for 'urethane or leave them as standard. I'd read somewhere that the perceived wisdom is to change the top wishbone bushes for 'urethane and leave the others as standard (or was it the other way around?)
Whichever way you go, I suspect that there will be others who disagree. Whatever you do, I'm sure you'll notice that a well set-up car with new bushes all round will be a revelation, irrespective of what type bush you fit.
Good luck with your choice,
FELIX456
Postby FELIX456 » Sun Oct 04, 2009 8:39 pm
I put poly bushes in the top wishbones of my '02 XKR and she drives really really well. However, the XJS was not notorious for chewing through them like the XK, AND is designed to be a more 'wafty' ride. Personally if I used my XJS for everything and the poly's were the same price as standard - I'd go poly, but if they're dearer I'd stick to standard and keep the waftiness. Anyway if you've still got 70 profile tyres as the XJS' mostly came with, how would you notice a tighter bush? (Can I put that?)
The XJS isn't supposed the be a sportscar - the 'S' stood for 'Special' not 'Sports' didn't it?
Either would do the job well, it's a matter of choice, in my Humble Opinion, but I'd keep her stock, not 'rodded'.
steveww
Postby steveww » Sun Oct 04, 2009 9:21 pm
From what I have been told here (thanks) and what I have read else where it appears that poly for the steering rack bushes and standard elsewhere is the way to go. My car is a convertible and I enjoy the wafting and I have no intention of creating a boy racer hot rod :D
masterb
Postby masterb » Sun Oct 04, 2009 9:43 pm
Not sure if the link was for me Pop? but i already have my bushes in the garage.
Nice superflex poly ones, sat in a drawer, and will probably stay there for some time unfortunately.
I suppose i could pay someone to fit them?
No, now that really is a silly thought, i can not allow lavishness to take a hold. :wink:
