Front cross member remove
steveww
Postby steveww » Thu Sep 17, 2009 9:30 pm
Ant hints and tips on how to remove the front cross member and keep the engine in place?
Is it possible to support the engine on the sump?
Telsmoneypit
Postby Telsmoneypit » Thu Sep 17, 2009 10:48 pm
You won't be able to support the engine from below. Any supports will get in the way when you remove the subframe.
I did this job on my 3.6 a while back...
I used a 5ft length of 4" x 4" extruded aluminium with oak 'feet' that sat on the join between the inner wing and outer wing. A length of stainless steel chain was wrapped around the manifolds and the Ally support, tensioned and bolted together. You do not want the engine to move while the subframe is off so make sure the chains are tight before you undo the engine mountings.
You need to get the front of the car off the ground a fair way so make sure you've got a big jack and some substantial axle stands before you tackle the job.
If you don't want to pi55 about bleeding the brakes, remove the calipers and hang them up under the wheel arches. Don't even attempt to remove the ABS sensors (if your car has them), trace the wiring back to the connector, disconnect and feed the wiring back through the inner wings. Bundle the cables near the hubs with ty wraps. I tried to remove the sensors. One came out cleanly but the drivers side sheared. A new one cost me £150 (hard to obtain secondhand)..OUCH!
Tool up with new lower pivots and bushes. At least one is going to be seized so BE PREPARED. You may have to destroy the old subframe to reclaim the bottom arms. I did.
Once you've drained the P/S hoses, disconnect them from the tank. The weight of the hoses, unless supported, WILL break the plastic inlet/outlet. New tanks are NLA and good used examples are as rare as rocking horse 5hit, so take them off!
When you finally come to drop the frame, make sure you have a mate available (pay with beer) unless you have access to a high lift pallet truck that is...
8)
Gareth Coomber likes to balance the frames on the sharp end of a jack, but he's a braver man than me.....
Once you've got the frame on the deck, the nightmare begins :lol:
PM me if you want any more advice.
Tel
masterb
Postby masterb » Fri Sep 18, 2009 9:50 am
Are you wanting to remove the front cross member? and not the front sub frame as described by Tel?
As far as i can see, if you want to remove the front cross member under the radiator.
You should be able to get away with removing the viscous fan, if you have one.
And removing the rad, ok its going to be a bit tight/fiddly but thats how i would do it.
However removing the front sub frame is another kettle of fish, as Tel expertly described.
And from the sounds of it i dont fancy that game, fortunately my front and rear frames are mint.
:wink:
steveww
Postby steveww » Fri Sep 18, 2009 10:35 am
Thanks for the replies.
It is the front sub frame I want to drop out. I need to overhaul the front suspension with new bushes, ball joints etc. From what I can see the current item looks in good condition and I would like to keep it that way so a good scrub and a fresh coat of paint once it is out.
I had though about a bar across the top of the engine but I was not sure if the wings were up to supporting the engine. Sounds like they are.
greeban
Postby greeban » Mon Sep 21, 2009 5:03 pm
Have a look at Pop's excellent write up below on his experiences. If your car is fairly 'new' and the subframe bushes are Ok you may just want to do what I did and overhaul the springs and dampers so you do not have to remove the whole subframe.
