Front suspension springs
Posted: Mon Aug 31, 2009 11:46 pm
by greeban
Took the plunge a few weeks ago and decided to de-rust my front springs on the celebration. Hired the spring compressor from JEC which worked great but you have to jack the car up really high as the compressor is very long- nobody warns you about this!
Once I got the car high enough all seemed to go well until I tried to undo the bolts holding the spring pan to the wishbone. I snapped both bolts which hold the shock mounting - these rust into the wishbone and you have to remove the wishbone to drill them out. Great fun!
I guess you could remove the nut with a splitter and if you wish to put in new bolts, drift the old bolts out - the machine shop I used tried to do this once they had drilled into the bolts but the buggers refused to move until they were almost hollow! The guy was using a very big hammer; no way could you do this with the wish bone on the car!
Fortunately I started on the nearside so did not have to remove the exhaust manifold to remove the fulcrum shaft which I would have done had it been the offside wishbone- phew! Tthe steering rack needs to be lowered however by removing the mounting bolt. I believe it has to be removed completely if you are removing offside wishbone.
Then to the next problem...LOL. As already mentioned in this forum the shaft has seized solid in the sub frame tube so I had to spend a day trying to free it. Tried heat, hammering, putting an impact wrench on the end to spin the shaft. Nearly gave up then I decided to try and use a puller on the end of the bolt pulling against the bush. This seemed to move the bolt a little so that when I clouted it with a hammer it finally moved. What a relief. Once out I was able to remove the wishbone and have the bolts drilled out. I then had the springs and pans shot blasted and powder coated.
On re-assembly had to be careful on the offside which had the shock mounting bolts protruding (used nut splitter on this side having learned my lesson on the nearside!) to ensure that the pan when being pushed up against the spring did not put to much pressure on these bolts and snap them. All in all a real pain in the a**??.
Pleased I have done it as it was an MOT advisory last year so may not have passed this year - also took the opportunity to spray some wax around the sub frame.
Thought you might find my experience useful should you try this :)
Posted: Tue Sep 01, 2009 9:44 am
by MichaelSB
Well done. :lol:
