Fitting new rear shocks
I am about to fit new rear shocks to my XJS. I have the workshop manual and a large tool chest. Any hints and tips on doing this?
I got caught out a while back with some replacement shox that used a different collet to the original, and the new ones came without a collet. Didn't take long to rectify, but annoying, all the same.
Assume you have a suitable spring compressor?
As well to note the exact positions of the distance piece and washers on the mounting pin, they always seem counter intuitive when I come to refit them - doing one side at a time helps.
Al McL
According to Jaguar the new shocks are the same as the old ones. I am reasonably sure that my spring compressor will fit, will not know for sure until I take one of the units off.
If there are any packing washers etc I will take notes and/or make a sketch of what went where.
Thanks for the tips.
Just to let everyone know I have successfully used a standard McPherson strut type spring compressor to strip the rear shocks. The collets were sized on and had to be cut off. You can get this type of spring compressor off a well known auction site for around £150.
