JD6H Front spring compressor
poprivet
Postby poprivet » Tue Jun 09, 2009 5:54 pm
What's with the price?
When I was researching what bits I would need to do my suspension, an article in a 2004 JWorld magazine said they were £140, In early 2008 when I bought mine it had gone up to £260. I notice that it is now over £342, and that's with the VAT reduction! The club says increases are due to the Euro exchange rate, but mine is clearly stamped 'Made in UK'
Yes, I know the club hire them out, but anyone is likely to need one for quite a long time if problems occur and the postage costs would be really high.
I'm actually glad I bought one when I did now as it looks like I will be able to sell it for a good profit :D Mind you, maybe I'll keep it for when I need it again in another 20 years time, I hate to think what a new one would cost by then.
By the way, it works really well. There is one hell of a tension in that spring.
Postby Brakebuster » Wed Jun 10, 2009 12:28 pm
you know whats coming , lol.......................
i am about to start striping mine down, how much would you want for the ' used ' :wink: set,
or how much to hire with a promise to return in the same condition or replace
cheerz
BB :P
almcl
Postby almcl » Wed Jun 10, 2009 1:35 pm
For others contemplating front spring removal, while the remanufactured tool is undoubtedly the quickest method, it is not the only safe method.
The one described here (first published in the JEC mag in the late '80s, if memory serves) works well but is more time consuming:
http://www.jag-lovers.org/xjlovers/xjfa ... index.html
Al McL
poprivet
Postby poprivet » Wed Jun 10, 2009 4:54 pm
BB PM incoming :wink:
Al, yes I'm aware of this method but if a bolts shears it would be a problem, if two shear it would be time to start running fast. Also the spring doesn't follow the same line as the rods so the pan will tip as it is being removed, snagging on the rods. If either the threads strip or the rod turns with the nut disaster is looming.
Each to their own I suppose, but those pictures make it look easy and really don't convey the shear power locked up in those springs.
almcl
Postby almcl » Wed Jun 10, 2009 10:40 pm
I've used this method half a dozen times and never had a problem with the pan snagging, the spring doesn't have a choice, it has to follow the pan, but lord, it is boring.
If worried about about the studs shearing, a trolley jack can be used to hold the pan. The nuts are loosened a few turns and then the jack is used to lower the pan on to them. That way the studs (I use four or five) are never holding the spring by themselves.
If you have access to the tool though, that's the way to go. It's a shame the Club's hire process is so unreasonable - you only get about a day's worth of hire unless you are prepared to use an overnight courier (£50+) to return the items.
Al McL
poprivet
Postby poprivet » Fri Oct 02, 2009 5:15 pm
This went cheap recently Ebay clicky JEC ones will be even more expensive after January 1st when the VAT goes back up to 17.5%
http://www.kelsey-forums.co.uk/yabbfile ... g_tool.jpg
Mr.Ian
Postby Mr.Ian » Sun Oct 25, 2009 8:42 pm
I don't mean to get anyones back up or offend the JEC as at least this tool is available.
BUT.
Why is it so expensive???????????
If that's all you get in that picture I just can't see how it merits that amount of money.
It only does one job.
I'm sure one made by a metal fabricator/blacksmith even as a one off job would be cheaper.
1978 XJ-S V12 Auto - Under Restoration
poprivet
Re: JD6H Front spring compressor
Postby poprivet » Tue Jan 17, 2012 4:43 pm
I just noticed the compressor price has now gone up to £459
http://www.jec.org.uk/shop/79675/suspen ... front.html
Just another £42 to go and it will be worth more then my car!
dhdove
Postby dhdove » Tue Jan 17, 2012 7:39 pm
Dear All
I get a feeling of deja- vu here, last time I got into a little warm water due to moderating (with a delete button) a similar thread so here goes........
First, I've checked out the JEC hire price for this tool, £40.00/week, tho admittedly plus VAT and carriage which I guess will be another £ 40.00 or so. However, springs off springs on, two hire periods £160.00? I know that this is not cheap, but it is safe and compared to the cost of front subframe replacement and/or overhaul is not excessive I think- how much will the total other costs be £K1.5? If you only want to change the springs then it will be a large portion of the total, but with the XJS nowadays who is going to do only that?
I think that everyone is now agreed that carrying out this work without the correct tool IS DANGEROUS.
I do not intend to moderate this thread that at this time, but, I urge you to take account of the dangers involved and the advice from your club - do not undertake this job without using the correct specialist tool - if you lose fingers or a hand the hire price will appear very reasonable ...............but too late.
I know that the posters on this thread are very experienced Club members but less experienced members may well access this thread for advice with their problem so I make no apologies for repeating what is a serious pieces of safety advice - USE ONLY THE PROPER TOOL!
Sorry to preach at you......... :shock:
Best
TonyS
Postby Brakebuster » Tue Jan 17, 2012 8:50 pm
nice one Tony , but ur a bit late :wink:
this thread was started last June , and went to sleep in October
and i agree , only the correct tools should be used for such a job , expensive or no.................
dhdove
Postby dhdove » Wed Jan 18, 2012 10:14 am
Thanks Vince - that'll teach me not to check post dates :oops:
However, the advice is still the same.......
TonyS
poprivet
Postby poprivet » Sat Jan 02, 2016 1:13 pm
Postby Brakebuster » Sat Jan 02, 2016 2:18 pm
a set sold on ebay two weeks ago for £250 ,
i only went to £150 before i was outbid
as i don't need them , i just ' wanted ' them , lol
poprivet
Postby poprivet » Sat Nov 10, 2018 1:39 pm
One on eBay in case anyone is in need.
Nothing to do with me by the way, just thought I would pass on the info:
https://www.ebay.co.uk/itm/Jaguar-XJS-a ... :rk:5:pf:0
greeban
Postby greeban » Tue Nov 20, 2018 2:00 pm
OMG - sold for £450! I was interested but not at that price!
I made my own earlier this summer as needed to replace lower arm bushes. It did the job and I will use again to do the other side now the weather has closed in. It is not ideal as can move on the spring pan (which is why the original has a big foot) but if you use guide bolts it is fine. Does take it out on the threaded rod but should be Ok for another run and then can easily buy another rod if I need to do again.
I did try to hire the JEC tool but was it was booked out for ages - have used in the past and is brilliant but making your own with the guide bolts will do the job.
