Front suspension overhaul in progress
poprivet
Postby poprivet » Mon Jun 08, 2009 6:46 pm
All goes to plan so far. The front subframe is out, the springs removed and both the large lower pins are out! I was expecting the worse, but there's no structural corrosion in it anywhere. A result I'm sure of annually spraying Waxoyl liberally all over the suspension.
The radiator could do with a replacing, a lot of fins are missing and there is a tiny leak in one corner. Although the front dampers are leak free and work correctly, the lower rubber bushings are shot. I doubt if they can be replaced separately? so new dampers may be required. The lower main suspension bushings showed quite a bit of play once the spring tension was removed so that should explain the knocking.
Removing the perished steering rack bushings caused some problems as the sportspack ones that were fitted have a large steel flange which prevents the use of a normal extractor and boy were they tight.
The next few days will be spent cleaning off over 20 years worth of grime before moving over the the engine bay where the sump will have to come off and repairs done to the inner wings. I welded a patch over the rust some years ago, but as access was poor, so was my welding. With the radiator and bonnet out of the way there is much more room to do the job better this time.
No pictures unfortunately, my camera has gone to Spain, long story :(
SimonR
Postby SimonR » Mon Jun 08, 2009 10:45 pm
Good to hear that the subframe is in fine fettle. I need to do this work on my car, really - mainly for the rustproofing and re-bush.
How do you tell if your car has the sportspack or not?
Apparently my first XJS had but unfortunately the suspension was so badly put together you probably never would have known!
I've heard that the biggest difference is probably made by replacing the steering rack bushes so it'll be interesting to know how the handling of your car changes after this.
Good luck with the rest of it and I hope the camera returns from Spain soon so we can see your progress!
All the best,
Simon R
Current cars: [b]1989 XJ-S 3.6 Manual[/b] & [b]2003 XK8 4.2L
[/b]
Previously enjoyed cars: other 3.6 Manual XJ-Ss and Daimler 4.0L XJ40s
Postby ptjs1 » Mon Jun 08, 2009 11:10 pm
Pop,
My suggestion is that you go for the 'urethane steering rack bushes rather than the rubber sport bushes. Best £20 I spent on my car!
Looking forward to the pics!
poprivet
Postby poprivet » Tue Jun 16, 2009 1:08 pm
The camera is back from Malaga so here is how things stand at the moment. One side is done but I'm waiting for some more parts to arrive before completing the other. The only bits that I'm painting are the brake shields, everything else will have a coating of black Waxoyl which has proved its worth in the past. The main beam has two internal ribs running its length, you can't see it in this photo but there are two lines of spot welds to show where they are so the whole subframe has many internal cavities which means it is practically impossible to de-rust and paint successfully. Thinned Waxoyl will be sprayed internally to every nook and cranny before the subframe is re-installed.
Any rust you can make out on the photo is only surface deep where the pain had failed in the past, my previous efforts with Waxoyl had preserved everything very well.
You may be able to see the three steering rack mounts in place, these are the 'Wat-Jag' ones which are of a stiff rubber rather then solid Polyurethane types. Time will tell how successful they are, I chose them as I heard that the Poly-Bush ones don't last too well.
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 4-2_tn.jpg
When I was cleaning up the springs and pans I did notice an important detail that I can't remember seeing in any 'how to do it' guides. Each pan has a drain hole, but if the spring isn't aligned correctly it will be completely blocked. The two pictures shown here demonstrate this so I would advise anyone to be careful when installing their springs to reduce future corrosion in this area.
http://i11.photobucket.com/albums/a183/ ... esmall.jpg
http://i11.photobucket.com/albums/a183/ ... dsmall.jpg
I originally had hoped that the car would be back on the road ready for Southern day, but the problems with my hand and knee now rule this out. As you may remember, I was going to SORN it at the end of August but I'm now bringing this forward. As time is no longer limited, I plan to make a proper job of cleaning and detailing the whole engine bay area.
greeban
Postby greeban » Wed Jun 17, 2009 10:11 pm
What did you use to hold the engine? Can you provide a picture, thanks.
poprivet
Postby poprivet » Thu Jun 18, 2009 5:46 pm
I have a steel pole supported by shaped timber in each wing gutter, this has a ring on 10mm studding holding a welded chain which passes around both the inlet and exhaust manifolds. I believe it is possible to buy lifting plates which would have been tidier. Th support is supplemented by a scissor jack and timber under the sump. The two work together to prevent the engine swaying sideways as its difficult to estimate the exact centre of gravity with the AJ6 engine being slanted.
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 4-1_tn.jpg
(Click on photo to make bigger) Maybe it was luck or good judgement, but the subframe came downwards easily without the engine moving at all.
When I take the sump off I intend to have an axle stand under the front pulley and another under the gearbox. I'm not getting under there unless I'm absolutely sure its all as solid as a rock.
greeban
Postby greeban » Thu Jun 18, 2009 5:55 pm
Thanks for the picture - just one observation: Is the engine support using just the one nut on the 10mm stud - if it is I am not sure it would hold without the trolley jack?
I would use 2 and you were very wise to use support underneath as well - I will definitely do the same.
poprivet
Postby poprivet » Fri Jun 26, 2009 4:41 pm
I've been feeling a bit more mobile lately so the sump has come off.
Here's a strange thing, in the bottom of the sump lurking in the black sludge was what I thought was a loose washer. It turned out to be a 1987 5p coin. The 5p's then were larger then today and as far as I can see there is no way in for something of that size once the sump is on so I can only assume it was placed by some mischievous engine builder. I've heard of strange items being placed in hidden areas of cars before, but this is the first time I've come across it myself.
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 4-3_tn.jpg
Both the sump and the oil pickup strainer had quite a lot of angular sharp pieces wedged in the gauze. It didn't look metallic or plastic but more like the sort of granules used in a foundry for cleaning up castings. Either way, the gauze isn't that fine mesh, so smaller pieces must have certainly passed through over the years. :?
I also took the windage tray off to inspect the bottom of the cylinder bores, everything looks OK with no obvious signs of wear. Here's a view not normally seen.
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 4-4_tn.jpg
After cleaning out the sump, it was evident that at some time in the past someone had grounded the sump on something resulting in a small gash to one corner. Its been filled with some sort of black epoxy putty. I never noticed it before on the outside as it looked like any other grime. It certainly doesn't leak so I'm happy for it to stay like it is. Viewed from the inside of the sump, it is clear that the putty was just pushed in from outside so I may well carefully degrease the area and re-enforce it with some JB Weld or Epoxy just to be sure.
I'm now having a boring couple of days cleaning and degreasing all the other bits.
poprivet
Postby poprivet » Sun Jun 28, 2009 11:46 am
I'm bored with all the cleaning and de-greasing, so I thought I would digress into a discussion about the upper ball joints.
Originally on the XJ-S these were held in place with two 3/8” UNF Bolts, the shorter of them having the head bevel ground to avoid fouling the disc at full lock.
However, all replacement upper ball joints available now are the XJ40 ones which are drilled to accept metric 10mm bolts. This results in the ball joint being a slightly sloppy fit by about 20 thou, not a major problem but not ideal. It is possible that over time the pounding on the suspension could result in the ball joint moving about creating more wear.
As I needed new bolts anyway, I decided to replace them with M10 metric ones to overcome the problem. They shank of the bolt was very tight in the arms, so I carefully opened that side up with a 10mm drill. The threaded end is a slightly smaller diameter and that side fitted without any modification.
The longer of the two is a M10 X 100mm. The other is M10 X 70 cut shorter to about 67mm and also I ground the head to emulate the shape of the original one as this photo shows. (All photos can be clicked on for a larger view if required).
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 4-7_tn.jpg
I should briefly mention a word or two about bolt strengths, which are marked on bolt heads as either 4.6, 4.8, 5.6, 5.8, 6.6, 6.8, 8.8, 10.9, 12.9 and 14.9 (which is defined by British Standard 3692 for anyone who wants to learn more). Nuts are designated 4, 5, 6, 8, 12 and 14 and ideally they would be matched to the same number as the bolt used.
The most commonly available bolts which are advertised as 'high tensile' will be grade 8.8 which I'm happy to use, but if you want to find higher strength ones that's fine. Whatever you do, don't use lower strength ones or heaven forbid any unmarked ones you found in a Pound store!
Back to the cleaning!
SimonR
Postby SimonR » Tue Jun 30, 2009 11:45 pm
Hi Pop,
I've really enjoyed reading this thread - most interesting as I'm sure I'll have to do this to my car sometime in the future.
How very odd about the 5p in the sump! I once found a spare seatbelt stalk under the carpet of a Maestro - the odd thing was that it wasn't a Maestro one! Pretty sure it was there from new though.
Happy degreasing!
[/b]
MichaelSB
Postby MichaelSB » Wed Jul 01, 2009 7:57 am
Keep it coming Pop
I am also finding your work of great interest even though your skill far exceeds my own.
Well done
Michael
Current
Jaguar XK8 4.2S Convertible
Polaris Ranger
T6.1 VW Campervan
poprivet
Postby poprivet » Fri Jul 03, 2009 4:44 pm
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 4-6_tn.jpg
Its back in – just! The round engine mounts and the brackets that go between them as we know are different either side on the 3.6 This was why I carefully placed them on the floor in their respective order. The same goes with the two front subframe mounts, which have both shims and washers, slightly different in thickness and diameter.
After my accident, being completely immobile, my kind neighbour who is very helpful, offered to tidy the garage for me. This he did, which included all the nuts / bolts, parts and items I had laid out.
I have all the part numbers, so I thought it would be simple to sort it all out, not so. None of the parts I needed to identify had any part number on them so I thought I would offer the subframe up and see what parts fitted best. My plan almost worked, the problem I had was one I thought might happen even before I started the whole episode, namely that the 3.6 engine, being canted over, could swing out of place unless the centre of gravity of the support was just right. It had. Searching many photos in books and on the net also proved useful, eventually I worked out what went where.
If I had been certain where the brackets and mounts lived, it would have been a simple job of levering and jacking things about until they lined up. Remember, you can't lift the engine up very far because the gearbox hits the transmission tunnel, the only way is for the subframe to rise up and engage everything. Anyway, with a lot of fiddle-de-diddle I got there. Of course if my camera hadn't have been in Malaga at the time, I would have had lots of pictures of where everything went. - There is a lesson to be learnt! I estimate the engine had moved to the right about an inch and canted over more at the same time. It's not the fault of the engine support, that worked perfectly.
I still have a mammoth pile of parts to go back in, many of which still require degreasing, rust treating, cleaning and painting. I will report back in due course.
(PS I still can't bend my finger but that doesn't seem to stop me working, although when I raise my hand as my neighbour arrives home I think he might be thinking I'm giving him a single finger salute for re-arranging the parts)!
:roll:
poprivet
Postby poprivet » Tue Jul 21, 2009 2:33 pm
Following the road-tax cokc-up, (see elsewhere on forum), I've had a couple of frantic days spannering which has seen the car become a roadworthy XJS again :D
Today, I took it out for a gentle 20 mile run to make see if all the nuts and bolts have gone back in the right places and I'm pleased to report a success! All the knocks, bumps and noises have disappeared, it steers and brakes straight. None of the oil and water fell out all over the road and nothing seems to have snapped off on the way.
It does 'feel' a bit different, not better or worse but different. I can't yet decide what it is, maybe it's because it really was cr@p before, or that it's because I've only been driving a Citroen for the last couple of months ?
I have booked it to a garage to have the tracking checked later in the week so perhaps after that I will know.
Unfortunately I have noticed a very slight oil weep from the filter housing which is a gasketless joint on which I used Hylomar Universal. This stuff goes on quite liquid but then evaporates to leave a fairly thick blue rubbery surface. Maybe I'll nip up the bolts a bit?
I'm sure the rad will still leak a bit. (I couldn't afford to have it re-built right now so I added a bottle of Barrs Leaks instead (Please Lord forgive me)! and I know the slight oil seepage will still leak until I replace the head-gasket at some point in the future. The wife keeps reminding me that I can't re-tax or insure it until I find another job, and that she isn't happy about me paying for the JEC subscription that's due soon :cry: apart from those minor points, all is well :lol:
Time will tell...
dhdove
Postby dhdove » Tue Jul 21, 2009 6:48 pm
Well Done Pop
Problems remaining sound like minor niggles, which you can easily sort when you feel like it.
So will you be taking the motor to Uppark House on Sunday? It would be great to have a chat, we'll be there if it's not persisting down.
Best Wishes
Tony
XJS Bulletin Board Moderator
poprivet
Re: Front suspension overhaul in progress
Postby poprivet » Thu Aug 06, 2009 4:04 pm
slight oil weep from the filter housing .... Maybe I'll nip up the bolts a bit
As a follow up, the tracking was out, which explained my tyre feathering wear on the insides and I now know what the 'different feel' is, the steering is much more responsive with the new rack bushings. The steering is pin-sharp now and a minute correction to the steering wheel points the car where I want it to go, very nice.
Nipping the bolts up resulted in a massive oil leak which came to my notice with smoke rising up from covering the exhaust. Examination showed an oil trail all the way underneath as far as the rear axle. I lost about 3 litres :( A mammoth clean up session and re- mounting the housing resulted in... more oil leaking :evil:
After calming down overnight, I made the decision to replace the oil cooler, pipework and adapter (after checking that the faces of all items was truly flat). I now have an oil leak free engine again. :D I don't know why it wouldn't seal without the adapter.
The water leak on the rad has stopped! Great stuff this Barrs :wink:
While underneath getting the oil off as it was getting perilously close to the brakes, I saw one of the rear dampers has a slight oil stain and the rear quarter panels have rusted a bit more then I had realised. Oh, and the oil pressure sender has failed as well. Just as I thought the list of work was getting shorter.
:cry:
Users browsing this forum: No registered users and 16 guests
