Identifying xjs rear suspension
Posted: Sun May 12, 2024 12:20 pm
by colin904
My 1994 xjs has damaged rear lower suspension bushes and I am trying to identify them so I can get replacements. Very grateful for any input on the images.
Re: Identifying xjs rear suspension
Posted: Sun May 12, 2024 5:13 pm
by ptjs1
colin904,
Those are the rear lower shock absorber mount bushes. As you can see from the Jaguar parts website, it's Part number CCC5634. Out of stock at Jaguar but usual independents such as SNG are advertising originals plus OEM options.
Posted: Sun May 12, 2024 9:02 pm
by davidr
Hi Colin904 - those shocks look like they have an adjustable base which would not be standard so I’m not sure that standard parts will fit
Posted: Sun May 12, 2024 10:30 pm
by ptjs1
Good point, David!
Posted: Mon May 13, 2024 1:54 pm
by poprivet
Something very wrong there. There should be no bushing sandwiched as shown and the tie bracket is missing.
The bushing is totally within the eye of the damper as pictured below in the Spax units I have:
Spax rear dampers
Tie bracket
The metal eye of the damper is clamped to the suspension allowing flex. I would be removing those units and investigationg further, it looks almost as if someone has added rubber washers, perhaps to take up slack due to the bracket being missing.
Posted: Mon May 13, 2024 4:38 pm
by ptjs1
Pop,
The tie bracket is only on the rear of the 2 shocks. The OP photo is of the front of the 2 shocks.
However, I agree that those external bushes / washers look strange. As you said, the bushing should be internal to the eye, with just a steel washer on the outside, prior to the nut.
See pic of the front of the 2 rear shocks with my adjustable Gaz shocks in situ
Posted: Mon May 13, 2024 9:47 pm
by colin904
Thank you for the replies.
The original installer kindly got in touch to say that the units were by AVO but they would now suggest a different make (Gaz).
A bit of googling suggests that the red polyurethene bushes were problematic from both a design and material perspective and didn't last.
I think the bushes were eventually redesigned but it looks like AVO have now ceased trading.
So maybe changing the dampers entirely is the way to go.
