Which height adjustable dampers for XJS 4.0
RodCotton
Postby RodCotton » Wed May 06, 2009 5:35 pm
My 96 4.0 Coupe has an 80 litre LPG tank in the boot making the rear of the car sit very low.
I'm thinking of fitting height adjustable dampers but am not sure which ones to get or which ones can be used on a late straight six.
Does anyone know if Spax G502s will fit my car or the part number for Gaz (gaz website displays a blank page)? Are there any other makes I can look into?
Many Thanks
Rod
PaulE
Postby PaulE » Fri May 08, 2009 11:54 am
The June 2009 issue of JWM has an article about XJS rear springs and dampers . Very informative and has some useful phone numbers. May help a bit. PaulE.
1994 Coupe AJ6 engine
almcl
Postby almcl » Fri May 08, 2009 1:30 pm
There is a Spax shock that can be fitted to the XJS but I don't think it will solve your ride height problem.
Data here :
http://www.spax-suspension.co.uk/p1324253.htm
Note that these are described as ride adjustable, they won't have much, if any, effect on the height. To change that you may need to replace the springs and if the car is radically different in weight distribution from manufacturer's spec, these may need to be made specially.
How much does the full LPG tank weigh? This will be the critical factor in calculating the new spring rate required.
There's details of the Gaz shox here:
http://www.kwengineering.org/acatalog/S ... S_4.0.html
These are height adjustable, but only appear to be usable up to '91 (pre-facelift perhaps?)
Al McL
Postby Brakebuster » Fri May 08, 2009 2:50 pm
the ' dampers ' otherwise known as ' shocks ' have no effect on ride height, only spring back dampening for comfort or firmness, thats what the adjustment is for....
ride height is altered by spring lengths or shims added or taken away to adjust the height
i have the full set of adjustable Spax on my V12 XJS , and the stiffer shorter sport-pack springs
you could always run it without a spare wheel, and half a tank of petrol.....??
