knock, clunk when moving off after medium to heavy braking
Posted: Thu Apr 30, 2009 10:54 am
by terry1
My AJ16 coupe makes a knock or clunk usually as i move off after braking to a standstill and sometimes as it comes to rest again usually after heavy braking. no noises evident when on the move. have changed brake pads, front wheel bearings, antiroll bar links and rear gearbox mounting.
any body out there suffered from this?
Terry
Posted: Thu Apr 30, 2009 6:05 pm
by dhdove
Terry
From your description it sounds as though the rear trailing/radius arm bushes are shot - a common problem. :?
The arms are prone to corrosion so it's worth changing the whole thing. Complete with bushes fitted they're about £100.00 each from a number of suppliers. You may wish to specify OEM if still available.
Best Wishes
Tony
