Getting the IRS Damper assemblies apart.
SimonR
Postby SimonR » Sat Feb 04, 2023 11:35 pm
Hello everybody,
I'm hoping someone can give me better instructions than the Jag workshop manual about the procedure for getting the collets out of the dampers to enable me to release the springs from them.
I've got all 4 damper assemblies off the car and some spring compressors synched up on one of them:
I can see the collets:
But how do they come out?!
I've tried levering them out and tapping various parts of the damper assembly with a hammer which has removed quite a lot of flaky rust, but I can't get the collets out :-( What's the secret?
Many thanks!
Re: Getting the IRS Damper assemblies apart.
Postby ptjs1 » Sun Feb 05, 2023 12:47 am
Simon,
It's just rust, age and tension holding them in. So, some WD40, gentle wiggling, even some heat. They'll eventually pop out.
Also when you're doing the next one, try and keep the spring clamps diametrically opposed to each other.
Good luck, you'll get there!
PaulGover
Postby PaulGover » Sun Feb 05, 2023 1:01 pm
You just have to knock the spring seat down so there's enough space to separate the collets and lift them out past the ring on the damper. I guess you might then need to hammer a screwdriver into the gap between the two collets to break the rust that's binding them.
SimonR
Postby SimonR » Sun Feb 05, 2023 7:02 pm
Thanks both Pauls - very handy replies.
I've had another session on them this afternoon and still no luck as yet. I used a mallet to knock the spring seat down, and I now at least understand how the collets got in there in the first place, but no luck in actually shifting them.
I sand-blasted the top of the spring seat so I can now see everything clearly and I also tried another damper but it's just as rusty and stuck fast. Believe it or not the sprint compressors are actually at 180 degrees from each other, it's just an odd photo above!
I've got one soaking in WD40 over night and I'll see what I can do tomorrow to get it moving. I think if I still have no luck I'll grind the lip off the damper and get the spring out that way. It would be a shame as I've got half a mind to see if I can get the OEM dampers rebuilt for the ultimate in originality, but my resolve to do that is rapidly waning!
I'll report back when there's good news to be had.
Postby davidr » Sun Feb 05, 2023 7:17 pm
I have found that a bit of heat helps but be careful - you don't want to get the damper contents hot.
It's just rust that's holding it together.
Penetrating fluid, some heat and repeated persistent percussion will get it in the end!
PaulGover
Postby PaulGover » Tue Feb 07, 2023 12:46 pm
Try putting a wedge such as an old screwdriver bit into the slit between the collets, and bash it in to force them apart.
poprivet
Postby poprivet » Tue Feb 07, 2023 1:55 pm
I had one that siezed solid, If I remember correctly an angle grinder was used.
They wern't worth keeping though.
SimonR
Postby SimonR » Tue Feb 07, 2023 9:17 pm
Evening all, well no luck so far. I've tried PlusGas, WD40, levering with a screwdriver and small cold chisel, hammering the cold chisel in between the collets to split them, sandblasting them... The only thing I've not tried is heat, but I need to get a new can of gas for my blowtorch.
I think it may be time to Dremel the lip off the dampers and declare them scrap. It's no big problem really - I probably won't get time to re-condition the Boge dampers and refit them to the IRS anyway. The most important thing is to get the springs out so I can re-finish them.
Incidentally - what are your views on sandblasting springs? I think I've heard before that it's not a good idea as it weakens them somehow. ISTR someone talking about bead blasting instead.
Postby ptjs1 » Wed Feb 08, 2023 12:39 am
Simon,
Why not carefully dremel or drill one of the collets themselves to try and get it dislodged? Once one is out or cut up, I bet you can move the other one.
SimonR
Postby SimonR » Fri Feb 17, 2023 6:52 pm
After a bit of a delay I'm pleased to say that I've managed to get the collets out.
I decided that seeing as application of muscle wasn't working, I'd better engage my brain and come up with another solution. The problem I had was that hammering down on the collets was hammering them in the wrong direction - what's needed is to get to the back of the collets and hammer them up away from the top spring cup. The issue with that is that there's no way you can get to the back of the collets with a hammer and drift.
In the end, I compressed the springs to give about 30 mm of gap at the top of the damper (i.e. the top spring cup could drop by 30 mm), got my small cold chisel into the middle of the spring, with the point against the bottom of one of the collets, then braced the bottom of the chisel with the handle of an adjustable spanner, using the spring to wedge it in place:
All that was needed then was a sharp tap on the top of the spring cup with a big hammer and hey presto, the rust seal was broken.
poprivet
Postby poprivet » Sat Feb 18, 2023 9:29 am
Good result. I would have been worried about any hammering whilst the spring was compressed. Some cheap compressors always beem to be at an angle and ready to let go.
SimonR
Postby SimonR » Sun Feb 19, 2023 9:45 pm
That ship had already sailed, Pop - I'd been hammering that damper for several evenings before I decided to put my mind to the problem and give my arms a rest. I did make several checks to ensure that the spring compressors were holding firm and still at the required angle for all four hooks to be seated correctly though, so all was well.
I made a video when I did the last spring this afternoon, in case anybody else wants to replicate this approach in the future - I couldn't find anything useful on YouTube about how to do this job so it's hopefully contributing a bit to the classic Jag scene.
https://youtu.be/xq0kRtTGXqI
Cheers for now :-)
