Which rear shocks to buy to replace the originals?
SimonR
Postby SimonR » Sun Nov 13, 2022 9:51 pm
I'm starting to think about which parts to buy to replace the worn out originals in the rear suspension rebuild detailed elsewhere in this sub-forum.
My car is a 1989 3.6 Manual with sportspack - and this afternoon I took off the original CBC5742 BOGE dampers:
These don't seem to be available anywhere so I'll have to buy something else.
I have seen a complete Bilstein B6 set from Simply Performance for £700 - but wonder if these are overkill or even a bit too stiff for my purposes. The car is only ever going to be used on the road and I'm building it for comfort as much as anything else - it certainly isn't going anywhere near a track. I don't mind spending the cash, but equally, there's no point in over-speccing it.
I've also seen KYB and Woodhead branded dampers available online.
I'd welcome opinions and suggestions on the matter - also, is it false economy to re-use 34 year old springs? They're visually pretty tidy, with a little flaking paint. Should I strip and re-finish them, or replace?
Re: Which rear shocks to buy to replace the originals?
Postby davidr » Sun Nov 13, 2022 10:00 pm
Hi Simon - I'll throw in my five penneth worth but hopefully others will pitch in too.
Shock absorbers - I would go for ones that both have an adjustable base so you can adjust the ride height and also adjustable damping. That way you can get the feel you want.
As for the springs, I have never yet found an aftermarket spring better than the originals. My advice would be to refurbish the originals if they are in decent condition
SimonR
Postby SimonR » Sun Nov 13, 2022 11:50 pm
Thanks David - Something like this?
https://www.ebay.co.uk/itm/115471967215
These appear to be clearance parts and I'm not necessarily planning to buy them on eBay.
Silly question - how do you know with adjustable shocks how to set them up initially so that they're close to OEM - or do you just fit them an experiment until you're happy?
Postby davidr » Mon Nov 14, 2022 8:32 am
Hi Simon - sort of what I mean but not quite. Whilst these are adjustable for the damping rate I would also look at ones with an adjustable base so the ride height can be varied.
As for setting them up, start at the middle setting and then decide if you want them harder or softer by trial and error
poprivet
Postby poprivet » Mon Nov 14, 2022 8:49 am
I agree that the height adjustable ones are ideal but I went for Spax G502 for simplicity of setup. Ended up three clicks up from the softest setting which I find is about right.
(Be aware that this particular model has now been discontinued, I'm not sure if there is a replacement.)
PaulGover
Postby PaulGover » Mon Nov 14, 2022 10:36 am
I note SNG Barratt have Monroe shocks as the "aftermarket repro" part for the facelift version, £110 each. The Monroe web site lists shocks for pre-facelift cars too (they're labelled "XJ coupe" rather than "XJ-S", which makes them a bit harder to find). That might be the same part number, I didn't check.
I used Monroes on my XJ6 many years ago; they seemed fine. AFAIK they're an old and reputable manufacturer. Being repro parts, they're not adjustable, but personally I've never understood how I should learn how to adjust them!
SimonR
Postby SimonR » Sat Nov 19, 2022 9:58 pm
Hello again gents, thanks for the responses - I think I may have made a decision!
I was looking at adjustable set ups and also the various aftermarket solutions and to be honest all the options got a bit daunting!! I think I've worked out that whilst a fully adjustable set up would be fun and add a different element to XJ-S ownership, it's probably not for me. What I'd really like is a new set of original dampers to keep the car as close to 'factory' as possible.
Whilst I was looking at all the options, ranging from about £300 a damper to around £90, I happened to find a pretty good deal on some Japanese KYB Kayaba ones:
https://www.ebay.co.uk/itm/174947881402
(Having said I wasn't all that set on buying from eBay!)
The fronts are about the same price:
https://www.ebay.co.uk/itm/174947881405
I've read up about the brand and that particular range of dampers and they actually seem pretty good, and others have reported that they're close to the OEM parts.
My plan is to fit these and see how they go (on the basis that they're probably worth the gamble) but to retain the original Boge ones and look into having them rebuilt for the ultimate in originality.
RobXJC
Postby RobXJC » Sun Nov 20, 2022 7:03 pm
I went for kyb dampers on my xjc restoration. Can’t comment on the ride quality yet as the rebuild is still progressing. What I’ve read is they are a sportier damper which I thought would compliment a set of sports eibach springs. To note though the paint finish is very light and wouldn’t last long especially if used on winter salt roads. I stripped and repainted my dampers using an etch primer first then the usual satin black. Don’t let the etch fully cure overnight. You want a flash dry and then apply the satin black so the etch bites into the steel and the satin black. If the etch dries fully I’ve found the top coat tends to chip off.
SimonR
Postby SimonR » Mon Nov 21, 2022 10:39 pm
Ha - in that case I'll let you know how they ride - I suspect that almost any new damper will be a vast improvement on the aged originals.
Thanks for the steer on the KYB finish, too. I'll do something about that before I mount them - I've had good results in the past with alloy wheel lacquer which is very tough but all but invisible when sprayed down on a lightly rubbed-down surface. I just hope it doesn't react with the original paint.
It was an expensive evening yesterday - I bought all six dampers and also replacement Brembo brake discs for the back end, to go with the callipers, flexible brake line and both sets of brake pads that I already have.
I'm off to collect a second hand sand blasting cabinet and parts washer on Thursday so that I can get some of the parts refinished.
Speaking of which, I've been looking at what finish I'm going to use for re-finishing the black parts and think this is probably worth a shout:
https://www.frost.co.uk/frost-chassis-black-paint/
I'll be spraying it, which will be fun because although I've had a compressor and paint gun for quite a while, I've never actually painted anything yet!! All the gear and no idea.... I'll be asking here about it when I get that far!
In dismantling news, I'm half way through dismantling the IRS, but although the impact wrench made mincemeat of the castellated hub nuts, I'm having difficulty getting the shaft out of the hub. Once I've got the hubs off and have removed the bottom central fulcrum shafts, I can get the cage off and attack the assemblies either side of the diff. I've also got two spare spacers that have dropped out somewhere. I suspect they go between the bottom of the front dampers and the mount on the bottom wishbone. I'll study the schematics unless someone knows. They're about the diameter of a 2p piece, and about 7 mm thick with a wall thickness around 5 mm - black in colour.
Pics to follow!
Postby ptjs1 » Mon Nov 21, 2022 10:52 pm
Simon,
I appreciate you've already made the purchase. But I think the biggest single reason for fitting height-adjustable platform dampers is because of the awful inconsistent quality of after-market springs and the difficulty of getting the exact same OEM spring that gives the correct ride height.
I fitted adjustable rebound Gaz dampers when my rear was rebuilt. I also fitted the Eibach sports springs. But I couldn't get rear ride height perfect. I ended up replacing the dampers with Gaz's latest adjusatble height platform dampers and everything has been great since.
As you've gone for non-height adjustable dampers, do be very careful on your replacement springs.
SimonR
Postby SimonR » Tue Nov 22, 2022 12:16 am
Thanks for taking the time to reply, Paul.
I can certainly see the argument for adjustable dampers, and I may well end up doing the same as you if I can't get it right.
I've taken DavidR's advice and will be re-using my original springs - they've done very little mileage and other than a bit of flaking paint are in very good condition.
It's just a case of stripping them and re-painting - or if the flakiness isn't too bad I may just strip the bottom couple of coils and re-paint that bit. I'll take options once they're off the old dampers and cleaned up.
RobXJC
Postby RobXJC » Tue Nov 22, 2022 12:35 am
Those spacers you described came off the lower suspension arm where the damper and spring unit bolts on.
Also if you are blasting back to bare metal, buy yourself a zinc plating kit. Gives everything a better chance of survival with paint over it or just looks good in zinc
I did lots of bits on my engine. The pullies on the front here I did.
SimonR
Postby SimonR » Sat Dec 03, 2022 9:54 pm
Thanks for the confirmation about those spacers, Rob - yes, I noticed today that the tubes on the bottom wishbones are shorter at the front than the back due to the need to get clearance for the radius arm mount.
I'll definitely be re-zinc plating the fixings, I'm just not sure whether I'll DIY them or take them to a local company.
Today I finally got time to crack on with the disassembly of the suspension unit - I nearly got everything apart and recovered various shims, noting where they were located. It occurs to me that I need to measure the thickness of the mounting area of my new brake discs, to make sure they're the same as the originals so that the camber is right.
The only bits I've not been able to disassemble are the hubs - I can't get the drive shafts out! If anyone has any pointers on that, they would be gratefully received.
Since I last updated, I've picked up a sandblasting cabinet and parts washer which I've yet to set up in the workshop - that's one of the next jobs now its apart.
Postby ptjs1 » Sat Dec 03, 2022 10:30 pm
Simon,
In case it helps (or worries!), have a look at this thread:
https://www.jaguarforums.com/forum/xjs- ... ld-225834/
SimonR
Postby SimonR » Sat Dec 03, 2022 11:23 pm
Thanks Paul - iiinteresting!
I'm beginning to think that I may well leave them where they are and just re-torque the nut and fit a new splitpin.
I can re-finish the hubs and driveshafts as they are so no point in splitting them and ruining the bearings.
I've made notes about the order in which everything came off so that I can get it all back together but there's a lot of work ahead!
