Rebuilding XJ-S suspension... Rear First.
SimonR
Postby SimonR » Thu Sep 01, 2022 10:57 pm
Hello everyone,
One of the jobs left to complete on my car is a suspension rebuild. It's still running on its original springs / dampers / bushes etc from 1989 and now that I've had the bodywork sorted and the entire underside Waxoyled, the suspension lets it down. The car also doesn't handle as well as some I've driven and there are issues I need to attend to, such as a leaking diff and the need to replace the rear brake calipers.
I've done suspension rebuilds on other cars (Austins and Rovers) so to some extent know what's involved, and I also have the Jag manual for the car, but I'm a little daunted and wondering where to start - front or back. I've got most of the tools needed and a decent workshop with an air compressor, but don't have a hydraulic press or a lift.
The plan would be to remove the units from the car over the winter, strip them down and get the components re-finished before refitting with any replacement parts that would be wise to use.
I visited KWE a few years ago and know that they advocate using a combination of poly and conventional rubber bushes so that's something I'd be interested in investigating - the car is going to solely be used on the road and comfort would be the major consideration, as opposed to anything hard or too sporty.
Has anyone with experience of this procedure got any advice or pointers?
PaulGover
Re: Rebuilding XJ-S suspension - where to start?
Postby PaulGover » Fri Sep 02, 2022 10:34 am
One view, and I'm sure there will be others: stick to stock bushes apart from the steering rack, where plastic works better and more importantly doesn't rot when soaked by the inevitable engine oil leak.
You'll find it well-nigh impossible to remove the lower wishbone fulcrum shafts from the front suspension. It takes hours on hammering to get the bl***ers to move unless someone's done it before and coated them with copperslip on reassembly, so if they look passable, leave alone. That assumes your front subframe hasn't corroded badly, sadly quite common as these cars reach 30 years old.
The rear radius arm front bushes will probably also be recalcitrant, but they will yield eventually. Check the mounting point for corrosion.
You'll find threads in the forum about supplies of replacement springs.
AFAIR, the Jaguar shockers are actually Bilstein, and a bit cheaper direct.
The front springs hold a frightening amount of energy; use a really good compressor - you can hire the Jaguar approved tool from the club if you don't have something strong enough. The usual coil clamps aren't a good idea because the spring ends are not parallel and hence the springs try to escape sideways.
If you're doing the lot, drop the rear subframe and dismantle afterwards. Do the inboard brakes and handbrakes too; they're so much more accessible, and probably replace the brake pipes and hoses.
Start either end, they don't interact and there's no common technique to transfer in working on them.
Postby davidr » Fri Sep 02, 2022 5:44 pm
Hi Simon - you may find the thread I started a few years back useful. viewtopic.php?f=48&t=10504&sid=5c844b87 ... 93b7640c58
I rebuilt the rear suspension on the 1989 V12 coupe I had at the time. There's pretty much a step by step account and it will all apply to your car. The only difference is the differential ratio.
If you tackle your front suspension you may like to start a similar thread?
Good luck! :D
SimonR
Postby SimonR » Wed Sep 07, 2022 9:57 pm
Gents - many thanks for the replies - really useful!
David - I've read your mammoth thread about your rear suspension rebuild - wow - what a job! I'll study it properly a few more times to get acquainted with what I've got to do.
The idea to re-plate all the fastenings is genius; I was wondering how easy it was going to be to purchase replacement parts and now it looks like I won't have to.
So that's the rear - maybe I'll start there then.
The front presents more of a conundrum because I'm wondering how far to go. The car would really benefit from a new clutch - or at least there's something unknown causing a very slightly 'clunky' gearchange. It's had clutch and flywheel work done before but clearly something's still not right. It also could do with a new rear gearbox mount.. Seeing as I'm going to have to support the engine when the front subframe is dropped, I'm wondering if I should bite the bullet and just take it all out. I think I have space in the workshop.... just!
Postby ptjs1 » Thu Sep 08, 2022 7:54 am
Simon,
I'd strongly suggest that you do the rear before the front. Although the rear can seem like a lot of work, if you address it slowly and methodically, it's all doable. And it's a great chance to address lots of areas such as radius srm mount corrosion, leaking diff seals, rear brake modifications etc etc.
Also the front requires support of the engine and the specialist tool to remove the springs, plus the almost inevitable subframe corrosion etc. So ease your way in via the rear cradle!
As regards the clutch, if that's the only reason for potentially pulling the engine, I'd try and verify if it really is the clutch at fault rather than hydraulics, gear linkage etc. It's a lot of work if it's not really necessary.
SimonR
Postby SimonR » Sun Oct 09, 2022 9:05 pm
Thanks to those who replied to this thread - I've formulated a plan!
I'm going to declare the car SORN at the end of this month (October) and begin work on removing the rear suspension unit with the view to completely refurbish it. I've bought 4 hockey pucks which I'll modify to protect the jacking points, and I've cleared out plenty of space in my workshop to get access around the car and also put the IRS cage on the workbench once it's out.
I'll use Davidr's thread as a basis for the work, and there are also some very useful videos on YouTube that give some insight on actually removing the IRS from the car - as with all things, working methodically and carefully will hopefully win the day. This one is pretty good: https://www.youtube.com/watch?v=vUkS1bQtp3Q although he's converting it to GM V8 power :cry:
I can already see some potential sticking points:
- Getting the exhaust apart
- Getting the radius arms off the bodyshell
- Finding the diff is leaking like a sieve when I take the propshaft off
- Slackening off the handbrake cable
- Getting the brake flexi disconnected (I may well just clamp it and cut it as it's being replaced anyway.
While the IRS is our, I'll take the opportunity to inspect and probably replace the rear parts of the exhaust as they're original and very rusty, and also rust-proof the area under the IRS cage. I've got 5 new tyres (Falken EcoRun301s) and will take the opportunity to have my wheels re-finished while the car is off the road. Will I be able to resist deleting the front silencers and putting a stainless exhaust on - probably not, but we'll see how finds stretch.
I plan to buy (or borrow if possible) a sand blasting cabinet so I can clean all the parts myself, and at the moment am planning to use POR15 to re-finish those parts that I re-use. I'm not a fan of powder coat because of its tendency to allow rust to creep under it once broached.
I've already bought several parts for the job:
- 5x tyres
- 2x brake callipers
- brake pads
- handbrake pads
- brake flexi hose
I suspect I'll be buying springs and dampers, radius arm bushes (if not complete arms) and several other parts as the job unfolds. My aim with the car is to do it properly and do it once where possible.
I'll report when there's anything to update you with!
RobXJC
Postby RobXJC » Mon Oct 10, 2022 9:31 pm
I rebuilt a late xjs irs last year. Mostly done at home but did need a hydraulic press removing old bushes. I had a fair few parts galvanised then painted rather than powder coated.
The combination of poly and rubber bushes makes sense. The irs weak point I think are the four vee mounts. Allows too much flex as they are rather close together. I fitted poly on the radius arms to help stop any rear axle steer. Really it needs a support around the diff to the body but that’s another story. For comfort it’s probably fine as it is.
I machined a few tools to fit new bearing within the hubs and the fulcrum pivots. If you get stuck just post with a few pictures.
Nothing is difficult but can be awkward at times.
SimonR
Postby SimonR » Sun Nov 06, 2022 2:54 pm
Thanks for the encouragement Rob!
The XJ-S is now SORN and today I began work:
I've so far had time to round the head of one of the screws that holds the ABS sensor wiring in place - a good start! As they're steel and screwed into an alloy part (the hub) I guess they'll all be corroded in. Small Helicoils are on the shopping list already.
I don't much like the look of the two bolts that hold the radius arms into the bodyshell either side. Hopefully the impact wrench will shift them.
I'll report back as progress is made.
RobXJC
Postby RobXJC » Sun Nov 06, 2022 3:38 pm
Before you unbolt that axle, put the front up on jacks/supports as well so the car is sitting flat. When you finally unbolt and drop the rear axle it will be a simple up and down movement via a trolley jack. You don’t want to be compensating angles as the axle is a fair old weight.
Any bolts that are corroded and tight, it will be heat gun time. Plumbers gas torch usually does the trick. Be careful and mindful of flammable items you could be heating.
Other than that, as you were :D
SimonR
Postby SimonR » Sun Nov 06, 2022 10:09 pm
Hi again Rob - yes I did think about getting the front up on ramps/stands but decided against it because truth be told I hate getting underneath cars and wanted it as stable as possible we'll see how much of a problem that causes later on :lol: I'm going to have to be careful when lowering it down but I'm sure I'll find a suitable solution.
You can say 'told you so' later on...
The good news is that the radius arm bolts gave way without drama and they're off- along with:
-Propshaft
-Antiroll bar
-Exhaust Joints
-ABS sensors
I have to thank the last person who took the radius arms and anti-roll bar off because all the threads were copper-slipped so the bolts just wound out.
One question that I do have at the moment is about the exhaust: I've undone the union just in front of the IRS (three bolts either side) and now the two rear sections are only held on by the hangers at the very back. I'm reasonably happy that the IRS will clear the front section as the end of the pipe is above the flange on the IRS cage, however, I can't work out how best to deal with the section that goes through the IRS to the back.
Is it just a case of leaving it where it is and gently withdrawing the rear sections when I drop the IRS?
I'm going to inspect the exhaust and consider if replacement is required or prudent while it's all apart - it would be a nice upgrade to put a stainless one on, and perhaps delete the intermediate silencers.
The other thing I did today was to take the Northern Irish registration number off the car and put it on retention. The original number has been re-assigned, which I prefer because it's got a Cambridge suffix, and the NI numbers look a bit tacky IMHO. It's actually quite a funny thing because the previous owner bought the NI plate to disguise the car's age in 1991 - just in time for the facelift XJS to appear. If anything he made his F-reg car look potentially older!
RobXJC
Postby RobXJC » Sun Nov 06, 2022 11:44 pm
Glad all is dismantling easily. I never have that luck. Regarding the exhaust my irs came off an xj6. Assuming it’s the same the rear silencer has a fixing to the other side of the wiggly pipes that go through the irs. So you need to unbolt the rear silencer and it gives a similar clearance to the prop side of the axle.
Also a kinda straight through exhaust came be simply made by either removing the centre silencers or the rear silencers. A friend recently did this to a later 6 cylinder xjs and the sound was glorious. Like a 50s/60s xk or e type with a bit more. Hard to explain but sounded spot on. His car he removed the centre silencer.
I’ve had a play with exhausts on different cars and do like to hear an engine tone. Recently removed the rear silencers off my v8 s type and replaced with just tubes and that sounds awesome now. The xjc I’ve been restoring is a 6 cylinder which will have a nice straight through system but without the crossover so should sound like a pair of 3 cylinder engines running in tandem which is similar to Jaguar d types.
Looking forward to hearing that running. Been nearly 5 years building that.
So back to your xjs, start up the engine if safe to do so with the rear silencers disconnected and have a listen 😊
SimonR
Postby SimonR » Mon Nov 07, 2022 11:22 pm
Yeah - I saw that joint in the exhaust pipe - it looks a bit crusty! Well, if it can't be removed without destroying it I guess I'll *have* to replace it with something nicer.
Please do share some pics of your XJC build - or let me know where you're posting them if I've missed them. Our first 'family' Jag was a 1977 XJ6 Series 2. A fabulous car.
I have decided to make a bit of a video log of the work done on the car, partly as a way of remembering what I've done but also partly to share it with other enthusiasts.
Here's the first instalment: https://www.youtube.com/watch?v=Sb5k-8IwrqU
RobXJC
Postby RobXJC » Tue Nov 08, 2022 12:01 am
No problem with pictures once I figure how to post them.
I do have a pistonheads thread under readers car Jaguar xjc 4.2. Nearly 5 years now.
It’s not a factory original restoration. It’s modified and how I would have liked it but it is using Jaguar parts. Even the colour change is Jaguar lavender but the insignia range version.
The body has been restored by a professional garage but I’ve restored/rebuilt all the mechanical items.
Roughly the engine is big valve series 3 xj6 running triple carbs, a Jaguar xj6 manual 5 speed to an outboard disc xjs rear axle. Also fitted is a rear anti-roll bar and upgraded front from an Aston db7. Springs are lowered eibach xjs on the front, the rears also eibach but I modified the spring seat holder so that it lowers the rear similar to the front but still keeping the spring under compression with no load. I made nylon spacer rings similar to what’s used on the front incase it’s too low. Currently it’s sitting at regular height but with no glass or engine fitted bumpers etc. Fingers crossed my workings out are correct 😊.
SimonR
Postby SimonR » Sat Nov 12, 2022 8:09 pm
That sounds like a pretty serious restoration, Rob - I'll have a look on PistonHeads - I love the Lavender colour and think it looks spot on on an XJ6. Such beautiful cars.
If you want to host photos, I can recommend a free Flickr account - you can have up to 1000 photos stored there and just link directly to them from forums by copying / pasting a pre-made link. That's what I do.
I had a good couple of hours at it today and am pleased to say that the IRS is now free of the car:
Second Video update: https://youtu.be/LmQq73swY8k
It turned out to be a simple job and everything came apart easily. I wanted to get every thing removed from the assembly before I dropped it as that way if it fell off the jack, it would not damage anything. The only bit that I could access immediately was the speedo sensor, however removal of the bottom plate from the IRS cage enabled me to get a spanner on the lower bolt, and a socket on the top one and it came out easily. I then re-fitted the plate, took the weight on a jack positioned centrally, removed the 8 mounting bolts and gently lowered the whole thing.
On one side I positioned a wheeled dolly so that the hub would drop onto it (a few blocks of wood protected the grease nipple), and with a couple of checks that everything was free, I just lowered the jack slowly until I could gently drag the whole thing out sideways.
Leaving the Radius arms in place helped a lot with stability as they stopped it tipping forwards.
That's the full extent of today's progress - now I need to carefully catalogue all the bits that came off, bag them up and give the working area a good tidy before I start taking it apart.
Cheers for now!
RobXJC
Postby RobXJC » Sat Nov 12, 2022 8:30 pm
Few pictures of when I did my axles on the xj6
