Cracks in rear hub carriers
pjknowles1968973
Postby pjknowles1968973 » Mon Aug 16, 2021 1:08 pm
In the course of replacing wheel bearings we have found cracks across the face of the hub carrier on both sides. On the left side it appears to be right through, see photos.
My garage here tell me they have seen this issue before, and have sourced second hand hub carriers only to find them cracked too.
Has anyone seen this issue before?
Is it going to lead to suspension failure?
Is it acceptable to weld up the crack?
New parts are available, not cheap, but if safety critical then no option.
Philip Knowles
TWR XJS 6.0l
PaulGover
Re: Cracks in rear hub carriers
Postby PaulGover » Tue Aug 17, 2021 11:18 am
That strikes me an odd place for a crack; you'd expect it to be on the flanges at the side, as that's where the stress will be concentrated (and where a crack would be significant). Are there other pictures; you say "photos", but there's only one at the moment. Is that black area below the crack a hole or some mark?
I've never heard of a carrier failing.
pjknowles1968973
Postby pjknowles1968973 » Tue Aug 17, 2021 4:04 pm
Paul,
Thanks for your response. Further web research shows this to be not uncommon, and as you say, not on the parts of the casting that take the main loads.
Consensus seems to be to monitor and only take action if the crack is spreading.
I have several photos, but this one was the clearest. The black spot is paint, presumably there from when assembled in 1988.
Also, I was cautioned v. welding, in that it would create a risk of distortion/misalignment for the bearings.
Finally, whilst I thought I could still get these parts new, it seems they are now 'no longer available', so I will keep an eye on the usual suppliers and see if they come back.
Philip Knowles
PaulGover
Postby PaulGover » Wed Aug 18, 2021 8:37 am
Thinking some more: I'd guess the forces of concern will be from the outer fulcrum shaft carrying the springs and dampers. They'll be transmitted via its bearings to the outside ends of the tubular bottom of the carrier. Thence into the flange above it, and then round the inverted U shape of the flange, spreading down to the half-shaft outer bearings. So the place to worry about would be the corner between the fulcrum shaft and the flange. I'd guess forces in the area with the crack would come from sideways (i.e. axially towards/away from the diff), maybe hitting a kerb at speed, though the tyre ought to smooth that out. Makes me wonder if it's an artefact of the casting rather than its subsequent life.
A common recommendation for cracks is to drill a hole through end of the crack so as to reduce the stress concentration and stop the crack growing.
All that said, I'm not a trained engineer or a metallurgist, so take it all with a pinch of salt.
PaulGover
Postby PaulGover » Wed Aug 18, 2021 9:31 am
Even more thinking: if you're worried about it, drilling is better than watching and waiting for the wheels to fall off. It's probably worth glueing a piece of aluminium rod into the holes - mostly for aesthetics and keeping road grot out.
Your next question will be "how big"; the end of the crack is at most 0.1 mm diameter, so even a 3mm (1/8") hole would reduce the cracking stress by 30:1. As a rough guide, I'd make the hole about the same diameter as the thickness of the casting at that point, adjusted by the available aluminium rod and drill bit diameters.
I'm still not a metallurgist or engineer !
