radius arms removal and replacement
adsB
Postby adsB » Sat Dec 06, 2008 6:11 pm
My facelift 4.0 seems to have rather rotten rear radius arms, has anyone done replaced these before?
If so firstly any ideas where the best place to jack the car up is and do I need to do anything to the suspension or do I just go straight to un-bolting the arm from the bottom of the shock and chassis. is it that simple?
Is installation just simply the reverse of removal.
I would be grateful for any help with hints and tip.
Ads
almcl
Postby almcl » Sun Dec 07, 2008 11:21 am
One method is to jack on the tie plate (under the suspension cage) and then support on the jacking points, possibly using a shaped block of wood between the body and the stands.
I've never had much luck with the large end and usually end up burning the bush with a gas welding torch, following up with similar treatment to the cup that gets left in place on the body. The outer ring of the big bush gets the hacksaw treatment, but if you're replacing the arms, that won't be a problem.
Disconnecting the shox (so that you can get the small end bolt out) is just tedious, normally, and extracting the special bolt similarly so, but not usually difficult.
Al McL
adsB
Postby adsB » Sun Dec 07, 2008 11:42 am
Hi Al,
Thanks for that, I'm going to have a look now but I don't have a welding torch so it'll have to be an investigation. Well utill I can work out a way to get the cups off.
Love your web site by the way and once again thanks.
Ads
Postby Brakebuster » Sun Dec 07, 2008 2:46 pm
when jacking up the car, take every precaution to ensure the car is stable, never just rely on a jack, you need some stands to be safe , jacks can fail at any time, especially if there is a ton of car up in the air at the time....
as for the radius arms, i would recommend releasing the body end first, make sure the bolts will turn to start with , and remove the locking wire....the bolts are ' self cutting ' and will be tight all the way , i would advise getting a new set of bolts installed before you drive the car, a full set can be got on ebay for £15 or so ,
the ' special washer ' at the wishbone end ( the one that is bent over to lock the bolt head ) is a single use only item, and should never be re-used.
the best way to get the cup of the bush from the body of the car is by way of a heavy cold chisel and lump hammer, a couple of sharp hits will make it drop off,,,
the lower wishbone end has the special bolt that is flatted on one side of the head to allow it to pass the shock stub on the lower wishbone, you need to undo the shock pins an drift towards the back of the car, a spacer behind the shock will drop from the pin, this allows the bolt to pass...
installing is much easier than removal...
as a sub-note....if the large bushes are mounted in the radius arm with the mouling holes to the sides, the radius arm will have a stiffer action than the moulded holes mounted front to back , its how the ' sports-pack' arms are setup...
adsB
Postby adsB » Sun Dec 07, 2008 5:30 pm
Hi BB,
Thanks for that, I just had a look and I can loosen the large bush end bolt which is promising. But I didn't have a large enough spanner fr the suspension end.
You mentioned 'you need to undo the shock pins an drift towards the back of the car, a spacer behind the shock will drop from the pin, this allows the bolt to pass...' do I need spring compressors or anything like that or is it just an undo job?
On a side note I spotted one of your other notes and I also use a Mac and the jag software doesn't run, so I was thinking of trying parallels with a copy of XP tomorrow I'll let you know if it works.
Postby Brakebuster » Sun Dec 07, 2008 6:03 pm
cool about the Mac 8)
i have a 24" aluminium 2.8 dual Intel with 4gig ram and 1 terabyte HD using OS-X , best machine i have ever had
as for the spring compressors....no , you dont need them as long as the wheel is off the ground when removed, and your not using the actual lower wishbone or hub to hold the car up....the spring will push the shock all the way down , a little jiggling may be required to re-fit, but only by a few mm's
from memory , the large bolt on the radius arm suspension end was 19mm , but i was using so many tools when doing it i cant remember correctly, lol
BE CAREFUL , if you remove the pin in full, the whole assembly will want to drop to the floor, as the springs/shocks hold them up, either chock and support from underneath, or tie up in place with strong cord or rope !!!!!
seeing my other post in ' General ' about my IRS rebuild may give you a few more clues
the lower shock pin has a nut on each end, its pot luck which one will come undone, if your really lucky the one on the side you need to remove will come off, simply drive the pin through enough to be out of your way , but if the far one comes undone, you will have to drive the pin out all the way past the radius arm bolt and take it out to let the shocks/springs swing free
use some ' copper grease ' when rebuilding everything, it will help a lot
just a note, after rebuilding my own unit, i have some genuine spare bolts and spacers etc, if you round anything off or break anything, give me a shout, i may have what you need
are you doing both sides ? as it would be better as it will even out the suspension geometry.....
adsB
Postby adsB » Sun Dec 07, 2008 8:10 pm
Hi BB,
Yep I've had a look at most of your posts and seen the one on the IRS It looks great finished. The only car rebuilding I have done was on a beetle, a very basic car. That said I must admit you and a few others on the site have inspired me to start tinkering well that and I was quoted £500 for the radius arms. So either I can do it and save a bit of cash for other jobs or it's got to go somewhere else any way.
In answer to your question about whether I am going to do both arms I think it would be a good idea, too. I will paint then in Hammerite and then fill them with waxoyle as well, hopefuly that will save doing tat job again.
I have seen what else you have done to your car and I'm very impressed.
Although I don't have a massive amount or work to do I'm going to try and start to maintain alot of it myself, I have noticed that you did your seat belt mounts was that difficult? As I have a problem there to. Was the Dynomat easy to install as I was thinking of that also. Better stop now or I'll be hogging all you time.
Thanks Again
Ads
adsB
Hi BB,
Thanks Again
Ads
Users browsing this forum: No registered users and 16 guests
