shock absorbers
kelsham
shock absorbers
Postby kelsham » Wed Sep 03, 2008 3:35 pm
I have been looking round ebay at the cost of rear shock absorbers for my 1986 cabriolet, there seems to be a vast range of prices. They are offering Boge, Monroe, at very low prices new, has any one any experience of their longevity? I prefer to spend money on buying petrol to use the car so am tempted by the offers. regards Kels
kelsham
shock absorbers
Postby kelsham » Fri Sep 05, 2008 11:24 am
Well a deafening silence, no one seems to have an opinion. I have just bought a set from the internet. A set of Boge rears for £100.00 I will let you all know how I get on when they arrive. Also how they compare with my old set. regards Kels.
PaulE
shock absorbers
Postby PaulE » Sun Sep 07, 2008 9:20 pm
Sorry to have missed your mail - as you say a deafening response as there was to my post about the same topic aug 21st. I am still thinking about a change of rears for next year and am bemused by the range of prices for dampers. Boge seem to be used as original equipment by some prestige car makers judgeing from their site , but we really need some opinion from somebody in the trade who has daily experience of the relative merits of the various brands. I am told that the Jaguar 'sportspack' green ones are made by Bilstein . Shall be interested in your result. What price were your Boge and where from? What mileage has your car done? My original green dampers seem to be starting to get tired at 58000 which does not seem a lot . PaulE.
kelsham
shock absorbers
Postby kelsham » Wed Sep 10, 2008 6:59 pm
Well I went ahead and bought a set of Boge at a good price from John Gordon via Ebay. He had a starting price of £99.99 if my memory serves me correctly I bid one hundred pounds at the end of the auction but was outbid at $102.00. I then received an offer from Mr.Gordon to buy a set at the bid price of £100 I accepted and have just finished fitting them and a set of rear brake pads today. I was too exhausted to do a test run,the old ones resisted removal.If you intend to replace yours wire brush the ends of the bolts holding the tops and use penetrating oil prior to removal. Wish I had. Also take care when you remove the shockers as there is a distance piece that goes through the top silentblock which falls out and rolls away. Well it is a Jaguar, I also struggled to remove the springs from the old shockers they were rusted in firmly. Some mild heat carefully applied to the locating ring helped. My cabriolet has covered approx 97000 miles. probably on the original shocks. when i press down the back of the car and let it rise, it does look as it is an improvement. I will post again soon I am about to travel to Southampton from Mid Wales which should give it a good test regards Kels
PaulE
shock absorbers
Postby PaulE » Thu Sep 11, 2008 10:41 pm
Tks for your prompt reply and await results. GAZ dampers read very well but are not listed for my 1994 car - only up to 1991. They will make some given details to work to but that is not a possibility with old dampers still in use on car and unable to measure. Wonder if yours are the same dimensions as mine? Dont throw the old ones away until we find out and perhaps you could measure for me? Does anybody know if they changed dimensions between 1986 and 1994?
shock absorbers
Postby Brakebuster » Fri Sep 12, 2008 11:37 am
all though a 1989 V12, i have fitted adjustable Spax dampers on brand new sports-pack springs ( NOS )
these dampers have a 14 point adjustment, and can be ' tuned ' to suit your requirements, they are also good quality
do a search on the internet for ' Spax XJS ' and several sites ( including spax home ) will pop up,
kelsham
shock absorbers
Postby kelsham » Tue Sep 16, 2008 5:28 pm
Hi all, well I have just returned from a journey of over 400 miles with my cabriolet since fitting Boge shock absorbers to the rear suspension.
When I tried the operation of the old and new in the vice I could just discern a difference in their operation. However once on the car I could feel the roadholding had improved and felt much more secure on the road.
Obviously the old shockers had deteriorated over the years, I now intend to change the fronts with a new set. regards Kels
