well, i didnt let it beat me, the rear cage is OUT !!!
no, its not gay
but it is fully removed from the back end of my XJS , there are several things wrong with it including four broken rear springs, and needing new discs and ancillaries , so it had to come out
did it on my own with the aid of four axle stands and two trolly jacks and a few blocks of wood , and a pocket full of trepidation..... :-/
first i had to cut out the exhaust system, i'm putting in a new stainless system , so no problems there, then i cut through the radius arms, no point in keeping those either, as i have new ones all bushed up ready to go in , and the rubbers had separated at the big end on both arms
then i had to remove the ABS sensors from the hubs, and the speed sensor from the diff, along with disconnecting the brake lines and hand brake cable she was ready to drop out,
i supported it by best guessing the balance point, and removed the 8 bolts for the brackets
then gingerly lowered the whole lot 1mm at a time making sure i wasnt snagging anything on the way and ensuring the balance was ok , then it all went Pete-Tong , well, almost, it slipped a little and my heart was in my mouth, not for my safety , but for the expensive bits i was about to drop onto the concrete, lol
it all worked out well in the end
i have a refurbished cage with new springs and shocks along with new brake discs and loads of other parts to throw at it
pictures will follow shortly
