Front suspension rebuild/re-weld ?
Posted: Wed Nov 07, 2018 11:45 pm
Hi,My 95N XJS 6.0 needs a front suspension,DIY recondition,together with all the other parts under my car.
I really want to go for the complete renew/sandblast and paint look.
However,I have noticed that the downward facing spring guide cups have rusted and in fact ,trapped and fallen down inside the spring and resting on the base plate.
These were originally spot welded to the main unit and the hole in the cup,I guess is where the correct spring compressor goes through.
I am worried that if I buy one of those £300-£500 xjs/xj6 units on eBay,they might or soon to go,the same way.
Does anyone know if I can you buy just these front spring cups,for me to re-weld on?
Obviously,when things are concerned near to those deadly springs,I have to be sure the welding is up to scratch.
Any thoughts?
Thank you
Any thoughts?
Thank you
