wandering under braking
sahtas1
Postby sahtas1 » Wed Feb 27, 2008 11:18 am
'92 facelift suffering from the front end pulling to the left under initial braking, then coming back straight. Has anyone experienced this before? Would be useful to get feedback before I start stripping all the suspension/ brakes/ bushes out. Car was mot'd only a month or so ago, not that that means a lot. The car has also developed an odd judder that comes and goes around 75mph but its not from the wheels. Any ideas?
Postby Brakebuster » Wed Feb 27, 2008 4:33 pm
sounds like its the brakes,
could be the pads, or discs , or a sticking calliper ( which is what i would look at first)
i doubt its gona be suspension elated if its only doing it under braking
Postby ptjs1 » Wed Feb 27, 2008 5:25 pm
I'd also go for a sticking caliper piston. I've had it on a couple of cars. My XJS always seems to wear its pads unevenly - more wear on inside pad.
I wouldn't discount tyre balance giving you judder at 75 mph. Most people never have their tyres balanced after they are initially fitted. Worth a look. My second choice after that would be prop balance. Stick a couple of jubilee clips around the prop (adjusters aligned together) and see if it makes it better or worse. Then move the clips up or down the prop or rotate the adjusters and then see what that does.
sahtas1
Postby sahtas1 » Wed Feb 27, 2008 7:13 pm
Thanks guys,
Has had new discs and pads quite recently but wouldnt rule out sticking caliper piston. Will check them out this weekend. Paul, great idea on the propshaft, was thinking it could be the problem as front tyres are new and just balanced.
Users browsing this forum: No registered users and 16 guests
